Old February 24, 2009, 01:59 PM
Default Heat From 2 4870's (512mb) Quick Question
If I were to slap 2 Sapphire 4870's in an Antec 300 with 6 120mm fans would they overheat, or would I be fine?
Old February 24, 2009, 02:15 PM
Should be, yes. Make the door fan an intake, so the cards get lots of fresh air, and preferably on a mobo that has a slot between the two cards.
Old February 24, 2009, 02:31 PM
Will a P5Q pro board do? It's all I have, just two slots.
Old February 24, 2009, 02:43 PM
yep, it'll be fine. It's not the best Crossfire board, because of the limited PCI-E lanes, but provided you aren't running like 2560x1600, it shouldn't affect performance too much.
And it's got the reqired single slot spacing between cards when dualslot cards are installed...one slot less, and the top card would be sucking in hot air from off the backside of the lower card, which will, of course, affect temps.
Old February 24, 2009, 03:18 PM
Silvgearx's Avatar
make sure you have fans that pushes a lot of CFM. And you probably won't be able to use a few harddive bays which will give better breathing room for the 2 gpus. Which sapphire cards you have? the ones with the black cover?
Old February 24, 2009, 03:32 PM
magictorch's Avatar
No they wont overheat. I had 2 in a quite poorly ventilated case and the temps were pretty good. I did aim a spot fan at the top card though. They run pretty cool to be honest they dump the heat out the back quite well when the fans turned up a bit.
Quick question jspot69 HTPC Systems & Software 4 February 6, 2009 06:39 AM
remounting heat-pipe assembly question SmogTown CPU's and Motherboards 1 January 12, 2009 12:22 PM
Quick Question /b/ derrXIII Video Cards 2 August 12, 2008 02:55 PM
Quick question Nodscene Power Supplies 2 July 7, 2008 11:27 AM
Intel 775 Heat Sink - QUICK question mattydies Water Cooling 3 June 26, 2007 06:57 PM
