Old February 22, 2009, 02:15 PM
Default Far Cry 2 Benchmarks too low??
Hi Guys,
I just ran the Far Cry 2 Benchmark, and my score seems a bit low, I was wondering if its my system thats holding me back?? (Specs on my Signature) - Settings are were set to Ultra High.
Score
Average Framerate: 37.34
Max. Framerate: 59.41 (Frame:295, 6.48s)
Min. Framerate: 26.45 (Frame:1278, 34.34s)
Settings
Demo(Ranch Small), 1440x900 (75Hz), D3D10, Fixed Time Step(No), Disable Artificial Intelligence(No), Full Screen, Anti-Aliasing(None), VSync(No), Overall Quality(Ultra High), Vegetation(Very High), Shading(Ultra High), Terrain(Ultra High), Geometry(Ultra High), Post FX(High), Texture(Ultra High), Shadow(Ultra High), Ambient(High), Hdr(Yes), Bloom(Yes), Fire(Very High), Physics(Very High), RealTrees(Very High)
Old February 22, 2009, 03:07 PM
magictorch's Avatar
Yes that does seem a little low? What driver are you using and memory overclock speeds? Im wondering if its the cpu holding you back as well, as it doesn't have a much cache and FC2 is very demanding cpu wise (it responds well to extra cores and high oc's but not sure about cache).
Old February 22, 2009, 03:13 PM
JD JD is offline
Well if the drivers are all fine, then I'll say it's the CPU as that's such a low resolution I doubt the GPU is having any troubles.
However do you honestly see a difference from Very High to Ultra? I surely didn't and the game ran better on Very High anyways.
Old February 22, 2009, 03:46 PM
magictorch's Avatar
The difference isn't huge but it is there when you go into villages or look at vehicles-not that big of a difference though.
Old February 22, 2009, 04:23 PM
MpG's Avatar
MpG MpG is offline
At higher resolutions, I know FC2 can easily break the 512MB barrier, which will hit a card with that much memory pretty hard. But since the OP is running 14x9 with no AA, it doesn't see too likely. Does any one here know what kind of Vmem usage the game has at lower resolutions?
Old February 22, 2009, 04:41 PM
JD JD is offline
Nope, dunno how to check either.
I like how GTA4 shows you that in the options.
Old February 22, 2009, 04:49 PM
MpG's Avatar
MpG MpG is offline
Rivertuner will track Vmem usage, actually. I'd check it myself, but don't have any working computers with FC2 installed right now, or with ATI cards.
Old February 22, 2009, 05:09 PM
MpG's Avatar
MpG MpG is offline
@OP: Run the benchmarks with Windows Task Manager open, and track the processor usage across both cores. That should give you a quick hint if you processor is bottlenecking anything.
Old February 22, 2009, 05:27 PM
DorkSterr's Avatar
Wow that is really low for 4870, I did the exact same benchmark with the exact same settings and I got
Settings: Demo(Ranch Small), 1440x900 (60Hz), D3D10, Fixed Time Step(No), Disable Artificial Intelligence(No), Full Screen, Anti-Aliasing(None), VSync(No), Overall Quality(Ultra High), Vegetation(Very High), Shading(Ultra High), Terrain(Ultra High), Geometry(Ultra High), Post FX(High), Texture(Ultra High), Shadow(Ultra High), Ambient(High), Hdr(Yes), Bloom(Yes), Fire(Very High), Physics(Very High), RealTrees(Very High)
  • Total Frames: 1966, Total Time: 51.01s
  • Average Framerate: 38.54
  • Max. Framerate: 54.39 (Frame:4, 0.09s)
  • Min. Framerate: 20.91 (Frame:831, 20.47s)
i7 980X @ 4510.5MHz | Rampage III Extreme | Dominator GT 2037MHz 7-8-7-20 C7* | ASUS 6970 945MHz/1460MHz | 2X Vertex 3 120GB RAID 0* (OS) | Corsair AX1200 | Obsidian 800D
Old February 22, 2009, 06:57 PM
JD JD is offline
Is the HD4870 512MB that bad?
Cause my Crossfire HD4850s can get a maximum of like 100FPS and the average was about 60FPS. That was at 1680x1050, no AA, Ultra settings.
Odd benchmarks Jonwall Overclocking, Tweaking and Benchmarking 5 February 8, 2009 09:43 PM
My Phenom II benchmarks Table21 CPU's and Motherboards 3 December 21, 2008 07:32 PM
Low Benchmarks? LegendofJubei Troubleshooting 3 August 28, 2008 11:15 AM
PCIe 2.0 vrs 1.0 Benchmarks? sswilson Video Cards 4 February 3, 2008 08:51 AM
XFX 8800GT Benchmarks! abs0Lut Overclocking, Tweaking and Benchmarking 3 November 12, 2007 07:00 PM
