Old February 22, 2009, 07:16 PM
Hmm I think it may be because of my powersupply or processor.. ive only got a Antec 430 Earthwatts, and ive got 5 fans on high, and when I game I put the card on 100% fan speed (I use noise cancelling ear buds) can't hear the noise :P, maybe my 4870 isnt getting enough power.. thats my guess.. or you guys are using better drivers.. Well either way next month im upgrading to a i7 System :] gonna use the same 4870 tho :]
Oh yeah, btw Im using Windows 7 :]
Old February 22, 2009, 08:48 PM
JD JD is offline
Oh Windows 7 is probably the issue then. Drivers are kind of lacking.
Maybe try installing Catalyst 9.2 and see if that helps, even though its not technically for Windows 7, it should still work.
Old February 22, 2009, 09:15 PM
Settings: Demo(Ranch Small), 1680x1050 (59Hz), D3D9, Fixed Time Step(No), Disable Artificial Intelligence(No), Full Screen, Anti-Aliasing(4x), VSync(No), Overall Quality(Custom), Vegetation(Low), Shading(Ultra High), Terrain(High), Geometry(Medium), Post FX(High), Texture(Ultra High), Shadow(Off), Ambient(Medium), Hdr(No), Bloom(No), Fire(Low), Physics(Medium), RealTrees(Low)
  • Total Frames: 2555, Total Time: 51.01s
  • Average Framerate: 50.09
  • Max. Framerate: 74.69 (Frame:401, 6.17s)
  • Min. Framerate: 32.49 (Frame:2114, 42.18s)
Maybe settings are too high , shadows and vegitation suck the life out of my 9800gtx+. I have some of that rendition ram in another comp and it's pretty weak stuff, win 7 runs badly for my games so far.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Odd benchmarks Jonwall Overclocking, Tweaking and Benchmarking 5 February 8, 2009 09:43 PM
My Phenom II benchmarks Table21 CPU's and Motherboards 3 December 21, 2008 07:32 PM
Low Benchmarks? LegendofJubei Troubleshooting 3 August 28, 2008 11:15 AM
PCIe 2.0 vrs 1.0 Benchmarks? sswilson Video Cards 4 February 3, 2008 08:51 AM
XFX 8800GT Benchmarks! abs0Lut Overclocking, Tweaking and Benchmarking 3 November 12, 2007 07:00 PM
