Old February 12, 2009, 01:26 PM
bojangles's Avatar
I had the same problem with the red lights a while back. My thread should be in the troubleshooting sub forum. I dunno... I just took it out everything from the case and tested it on a large box. Worked fine after that. Check for grounding issues in your case like pegs and dust. I'll find the thread when I get on my computer.
Old February 12, 2009, 01:30 PM
donimo's Avatar
you have onboard vid?
just take out ALL cards then, it should boot into bios just fine regardless of settings.
just 1 stick of ram and cpu and NOTHING else...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old February 12, 2009, 02:55 PM
aviduser's Avatar
Ok, new info.
I used a different PSU, same results. Then I removed the card and installed it in another computer, fans boot up on the card and the red light disappears. However still no visual, I tried using different ram sticks, but nothing.
I tried last night removing everything from the case and booting off a cardboard box, then completely reassembled the whole system to no avail.
Donimo- I'll give it a shot.
Old February 12, 2009, 03:06 PM
donimo's Avatar
did it work on the cardboard box?
if it DID work you may have an issue with the mobo shorting to the case somewhere.
if it DIDN't work you can scratch that off the list as a possibility
My HP wouldnt boot when the psu started to go, took my x800 out of it and it worked into BIOS at least off the onboard.
I thought the vid card was toast so I ran it off the onboard for a month while I RMA'd the card, then the PSU went all the way and took my HD with it with all the pix from xmas... Not that that is your issue, just killing time till my shift is over.
Old February 12, 2009, 03:27 PM
aviduser's Avatar
Nope, no luck on the cardboard.
Just threw everything back into my old case/mobo/processor. Everything works fine, boots up no problem.
So far.
Ram is fine
Video Card is fine
Hard drive is fine
Psu is fine
Mobo?
So it isn't a shorting issue seeing as I have the same problem out of the case, Card won't work in either Pci-E slot. No luck at all trying to use onboard video..I dunno why the mobo would work one day then not the other if its the problem.
Maybe I should just rma it and go back to my phenom 9550 till it gets back...
Old February 12, 2009, 03:56 PM
donimo's Avatar
process of elimination, if all the components work in the other system then the issue is with whatever was changed, ie: CPU and mobo.
its like sherlock said "if you elliminate the impossible then you are left with the truth" or something like that...
It "could" be the cpu, but I would lean strongly towards the mobo being pooched.
Also, the reason the mobo is pooched could still be the PSU so be careful when you use the psu on anything else as you may end up with 2 dead systems!
Old February 12, 2009, 04:04 PM
aviduser's Avatar
Shouldn't I get some "beep" codes from the mobo if the processor is gone?
I'd be pretty dissapointed if it is the Psu, I dropped too much money on that thing just to have something reliable. Time to go pack up the mobo I suppose.
Old February 12, 2009, 04:39 PM
Try the 9550(or older AM2 chip) in the board,if it boots then you just need a bios update
if it doesn't then look like RMA time
  #19 (permalink)
Old February 12, 2009, 06:28 PM
aviduser's Avatar
Nah, I already flashed the bios to the newest version, which supports the phenom II. I threw the phenom 940 in my old rig to test it and it works fine. In fact I'm using it as I type this.
I also tried installing everything outside of the case again, no luck. I can't see any blow capacitors or anything. Hopefully I can get it replaced or at least repaired.
Gaming with Light editing work. Phenom II build? manbearpig New Builds 3 January 22, 2009 06:47 AM
Does The Razer DeathAdder Have a Control for it's Light Gameplaywarrior Peripherals 7 December 30, 2008 12:55 AM
Economical Rig for F@H, and Light Gaming. BALISTX New Builds 7 November 10, 2008 07:36 PM
64-bit woes evancolson O/S's, Drivers & General Software 2 June 6, 2008 10:14 PM
Need a Very Thin and light, 15" LCD, VGA or DVI Cptn Vortex Display Units 0 December 11, 2007 12:08 PM
