Old February 11, 2009, 07:00 AM
Eagle Eye's Avatar
I second Sky recommendations, although a videocard might not require additional power it does put a lot more stess on the system and your psu won't last near as long. Be very mindful of any additional items you put in, like another HDD or a more powerful cpu in the future.
Regards,
EE
Old February 11, 2009, 03:40 PM
Ok after booting and rebooting and hitting f1 I was able to get into bios It was set to video adapter moved it to onboard video saved reboot and was able to get signal. I loaded the drivers and every thing seems to working .thanks to all. For what I am using the card for I paid 89.00 do I really need exchange?
Old February 11, 2009, 08:04 PM
Ok sky Im goin to look into the hd4670 I trust your knowledge of vid cards is better than mine. Thankx again.
Old February 11, 2009, 08:11 PM
Caznoob's Avatar
Another thing is that ATI is often a better choice for HTPCs. It may be just me but I have always found ATI to have a better quality image than nVidia cards. I'm not a fanboy either I have an 8800GT in my main comp and a 4550 passive cooled in my HTPC. You won't be disapointed with the 4650 or 4670. They also can do 7.1 audio via the correct HDMI connection :)
Old February 12, 2009, 05:43 AM
I've been trying to get the 5.1 7.1 to work through the hdmi cable. I have the spdif header patched to the vid card but no luck with sound.
Old February 12, 2009, 06:55 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Search Google for Realtek ATI HDMI Drivers. The you need to go into your Device Manager in Windows and switch the audio output to your HD 4670.
Old February 12, 2009, 06:58 AM
Sounds like a plan sky thanks
Old February 12, 2009, 07:03 AM
SKYMTL's Avatar
Just make sure that you install the 8.12 or 9.1 drivers properly. If you need help with that, let us know.
  #19 (permalink)
Old February 13, 2009, 05:18 PM
thought I'd work on getting sound out my hdmi tonite but no luk so far I belive I have the latest realtek drivers installed audio version 6.0.1 directx 10.0 audio codecs alc838 Can not locate 8,12 or 9.0 even tried google. Im also still playinh with the 9500gt. The realtek sound manager has a digital coax out put and I could buy a cable to patch from pc to my yamaha 2700 but I'd rather do hdmi.
  #20 (permalink)
Old February 13, 2009, 06:04 PM
SKYMTL's Avatar
Whoops, how are you playing with both cards at the same time? You should uninstall the drivers from one before working on the other.
Zotac 750a mobo? upcoast604 CPU's and Motherboards 0 January 8, 2009 11:49 AM
9500GT cooler Sniper Video Cards 5 November 10, 2008 06:52 AM
ASUS Launches Overclocked GeForce 9500GT MAC Press Releases & Tech News 0 July 29, 2008 09:45 PM
First Look: NVIDIA GeForce 9500GT 55nm Graphics Cards MAC Press Releases & Tech News 11 July 9, 2008 06:42 PM
