Old February 8, 2009, 08:49 AM
arrived and hooked up now
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old February 8, 2009, 08:52 AM
Nice, the analogue PWM should allow better clocking over the digital of the reference cards.
You may also want to try two bridges(can cause issues in some ocnfigs) with the bridges connected in opposite directions. you'll see JP1 and JP2 on the bridges...JP1 on top card, first bridge, JP2 on top card, second bridge.
Old February 8, 2009, 09:24 AM
hmm ive been reading up on it and apparently using both bridges can cause more issues than anything
Case: HAF 932
Mouse: Logitech G9
Old February 8, 2009, 10:14 AM
bojangles's Avatar
Pretty sure you only need one bridge. The other slots are meant for adding more cards than 2.
Old February 8, 2009, 05:19 PM
Silvgearx's Avatar
Good choices
4850 is only 10%-15% better than the 4830. ( if i remember correctly)
will my psu support 9800gtx+ ? AFG34 Power Supplies 8 November 14, 2008 09:15 AM
9800gtx OC Bdog454 Overclocking, Tweaking and Benchmarking 2 July 12, 2008 07:28 PM
9800gtx OC Bdog454 Video Cards 0 July 11, 2008 08:18 PM
cooler for 9800GTX kruzn4evr Video Cards 7 June 2, 2008 08:50 PM
