Old February 5, 2009, 04:30 PM
Default Video Card recommendations
Hello
I've got a Gateway GT5634H system that has the NVidia GeForce 8500 GT video card in it and reading, it seems to be a low end video card. (maybe middle). If I was wanting to upgrade to a better video card, which one would you's recommend?
I do a lot of everything on this system, from gaming to graphics work.
Thanks in advance for you opinions and advice!
Old February 5, 2009, 04:35 PM
sswilson's Avatar
Best bet before anybody gives you advice on this is to get any information you can off of the power supply in your system. That's going to make the biggest difference as to what recommendations folks will make.
They'll also want to know your budget.
Old February 5, 2009, 04:37 PM
Silvgearx's Avatar
Gateway Support - Specifications
Are those your system specs?
If so, what monitor resolution?
And what games will be played?
donimo's Avatar
wattage (total and 12v rails) and whether or not it has a PCIE 6/8pin connector.
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old February 5, 2009, 04:55 PM
Silvgearx's Avatar
it likely wont have 6/8pin.
Old February 5, 2009, 06:14 PM
Eagle Eye's Avatar
You're looking at a PSU upgrade and a VGA upgrade.
I had to do the same on an older Gateway system, after adding a second HDD and another videocard (7600GT) I nearly killed the stock psu.
Answer this and we'll be able to determine what you'll need.
Old February 5, 2009, 06:28 PM
WolfBane's Avatar
lol i have a 8500 gt card sitting here :)
wunder if that would help him any if he dosn't have the requirements for a newer vid card?
Old February 5, 2009, 06:49 PM
JD JD is offline
If that's the right link of specs, then yeah 300W ain't going to cut it.
If you can't afford a PSU, then the best you're going to get is a HD4670 IMO which go for about $100.
Old February 5, 2009, 08:02 PM
Eagle Eye's Avatar
Btw Maxtor welcome to forums
Old February 6, 2009, 06:27 PM
Yes, the link that 5ILVgeARX posted is the specs on my system. Didn't realize they had put such a small power supply in this thing.
What if I up the power supply in it? That's not a big deal. Any suggestions as to a power supply going by the specs of this thing? (hopefully not something EXTREMELY expensive.......lol) Keep in mind I'm in Canada so would likely be buying from Newegg.ca or directcanada.com
Right now I am running 1680x1050 for screen resolution but I don't really have one that I prefer. Guess I never gave it much thought.
I play all sorts of games but most of them lately have been Call of Duty and stuff like that. I also do a lot of flight simulator games.
Thanks for all the replys and thanks for the welcome to the forums!
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 10:27 PM
[WTB] Video Card Table21 Buy/Sell & Trade 5 November 21, 2008 09:26 PM
WTB: video card Skyllz Buy/Sell & Trade 5 October 14, 2008 06:03 PM
WTB PCI-E Video card with Video out Taichan Buy/Sell & Trade 0 June 9, 2008 08:17 PM
To buy: AGP video card Moi_meme22 Buy/Sell & Trade 9 March 9, 2008 03:57 PM
