Old January 29, 2009, 02:39 PM
Default Looking for a TV Tuner
I want to get rid of my old TV in my room since I don't have a lot of room. I decided I'd get a decent TV Tuner. I found the following at futureshop.ca
Future Shop: Computer Add-Ons: Sound & Video: Hauppauge WinTV HVR 1800 PCIe HD TV Tuner Card
Future Shop: Computer Add-Ons: Sound & Video: Hauppauge WinTV HVR 1600 PCI Card HDTV Tuner
Future Shop: Computer Add-Ons: Sound & Video: Hauppauge WinTV HVR 1250 PCI-E Tuner Card
Future Shop: Computer Add-Ons: Sound & Video: Hauppauge WinTV-Go Plus
I'm leaning towards the first one since it has component input so I can hook up my PS3. want I want to know is, how does it display on the screen. is it a simple window which I ca shrink to allow me to surf while watching or is it restricted to full screen only?
thanks
Old January 29, 2009, 04:55 PM
chrisk's Avatar
Folding Captain
I have the 1600 you linked and its a great card.
It comes with software that i don't use (I think WinTV 2000), which will allow you to go full screen or windowed. I was not too impressed with it myself, but is as good as most that will come with any tuner you will buy. However, I decided to buy SageTV as the media software, which works well with the Hauppauge cards you listed (at least the first two).
As for your PS3, perhaps you can just plug your PS3 into your monitor directly? Does your monitor have an HDMI input?
Fold for team #54196
Tv Tuner In and Out? CactusJoe HTPC Systems & Software 1 January 21, 2009 07:48 PM
TV Tuner Cards Wein13 Video Cards 0 September 19, 2008 08:54 PM
Tuner for Starchoice? lowfat HTPC Systems & Software 18 September 3, 2008 03:09 PM
Looking for a new Tv Tuner Card........? Canadianguy Peripherals 5 June 26, 2008 12:21 PM
TV tuner box build the_bandit87 HTPC Systems & Software 8 May 17, 2008 12:59 PM
