Old January 27, 2009, 02:01 AM
Default i need an graphic card for x4 slot
Plz can anybody help me, i want to put a graphic card in my "intel server Board s5000vsa"
but i have only x4 slot free, i searched about an graphic card for this slot but i found nothing.
Plz tell me if you have an suggestion..
Ps: if it is nvidia card is better.
- PCI Express* x4 (x8 Connectors) Slot
Sincerely Jksynapse.
Old February 10, 2012, 10:37 PM
Graphics card? There is no way in hell
Old February 10, 2012, 10:40 PM
Soultribunal's Avatar
Is your PCI-e Slot Close ended or Open ended?
SolisTech, its very possible. You should see the people who opened up there PCI-e 4X slots just to jam a few more Folding Cards in.
You will be bottlenecked, but you can do it.
-ST
www.realhardwarereviews.com
Old February 10, 2012, 11:05 PM
Like ST said, you can put a full 16x card in a 4x slot if the back is open.
If it isn't open and you don't want to dremel it open you can always buy a 1x card and put it in. Nvidia and ATI/AMD had a few offerings, but the pricing was never great. The Nvidia ION cards are pretty hard to find too.
Quick look at NCIX and this is all there is: Powercolor Radeon HD 5450 GO!GREEN 650MHZ 512MB 667MHZ DDR2 PCI-E1 DVI VGA HDMI DIRECTX11 Video Card - PowerColor - AE5450 512MD2-SH
Old February 11, 2012, 07:45 PM
Newegg has slightly more offerings than NCIX. Still, not that great, because well, it is a PCIe 1x card.
Old February 12, 2012, 07:46 PM
If you could physically put a 16xcard into it, they'll be no problem; Only difference between 4x and 16x is that the 16x has like a 5% performance increase
Old February 18, 2012, 04:27 PM
MARSTG's Avatar
your problem is similar to mine, you will need a slot extender, is around 25$ at newegg.ca Newegg.ca - StarTech PCI Express X1 to X16 Low Profile Slot Extension Adapter Card Model PEX1TO162
You mount a low profile card on it or if we speak of Newegg they also have a GT520 on PCIE X1 slot, or get a low profile GT430 on the slot extender or a Radeon 6570 whatever you consider. My radeon 4550 with 256MB DDR3 is not jumping over 25fps in NFSHP2010 at 800x600 but I think the game might be a bit much for a 3 year old low end card. An X4 to X16 adapter can be found here for 42$ PCI Express X4 to X16 Adapter Orbit Micro
7F bios error and no graphic output Wolfx25 Troubleshooting 4 December 27, 2008 10:31 AM
Single-slot coolers S_G Video Cards 1 October 25, 2008 03:15 AM
Dual CPU slot board? 3.0charlie CPU's and Motherboards 19 February 1, 2008 08:30 AM
Single slot bracket? 3.0charlie Video Cards 9 December 4, 2007 03:47 PM
Video card hook up slot mailaw Video Cards 6 July 26, 2007 07:58 AM
