Old January 22, 2009, 02:58 PM
zlojack's Avatar
Default EVGA Voltage Tuner Coming!
Source
This is awesome. Very high clocks on the way!!!
I wonder what will happen now in the GTX 285 tri vs. GTX 295 battle!
ORIGINAL: EVGATech_JacobF
Have an exciting new utility to show today that is coming soon
A couple of facts:
  • First version of this utility will support all EVGA GTX 260, 280 and 295 cards.
  • Will work ONLY on EVGA graphics cards, and ONLY for EVGA registered users.
Check out the below example, a small VCore boost increases my clockspeed 100MHz!
EVGA GTX 295 Air Cooling
Standard Voltage (1038mV)
Max Clocks: 684MHz Core / 1476MHz Shader
Increased Voltage (1263mV)
Max Clocks: 783MHz Core / 1692MHz Shader
Old January 22, 2009, 03:08 PM
Cptn Vortex's Avatar
Awesome, yet at the same time....there are going to be alot of dead cards...... lol
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
2 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old January 22, 2009, 03:13 PM
Soultribunal's Avatar
I hope they have a confirm pop-up before your selected voltage comes into Play...
Or I think Mr. Vortex is bang on lol!
ST
www.realhardwarereviews.com
Old January 22, 2009, 03:16 PM
sswilson's Avatar
Wouldn't it be safe to assume that they'll build in the same kind of upper limits that CCC overdrive has? There must be some overhead to the spec.
Old January 22, 2009, 03:17 PM
zlojack's Avatar
I would imagine that they'll have some sort of limit.
Old January 22, 2009, 03:24 PM
thenewguy001's Avatar
I'm not optimistic about this. Nvidia and their partners really dropped the ball with the 9000 series cards and voltage regulation. There's a circuit over-voltage protection switch built into the gpu cores that shut down the cards when certain unsafe voltages levels were reached. This basically meant overclocked (both user and factory) cards were shutting down for no discernable reason in the middle of intense 3D applications. It took a long time for this to be discovered and there was a huge thread about it on the EVGA support forums. The only solution there was is to underclock your factory OC'd card back to stock levels. As you can see from my sig, I was affected and pulling my hair out trying to figure out what part of my system was unstable during games.
i5 2500K @ 4.0 GHz
2 x 4GB G.Skill Ripjaws X
Patriot Pyro 240GB
Gigabyte HD 6970 OC
Gigabyte Z68X-UDH3-B3
Seasonic 760W
Coolermaster Hyper 212+
CM690 w/ 1-80mm, 6-120mm fans.
Old January 22, 2009, 03:27 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
"Registered Users". Haha. Count me out since none of my 14 EVGA cards is registered considering they are review units..
Old January 22, 2009, 03:40 PM
sswilson's Avatar
Heh... I'm sure they'd be happy to give you a registration code to try it out SKYMTL. :)
Old January 22, 2009, 03:44 PM
zlojack's Avatar
So far it's only for the GTX series cards. EVGA really seems to be doing a good job lately with E-LEET and Precision. I'm optimistic about this program.
Old January 22, 2009, 10:40 PM
rjbarker's Avatar
Yep I tend to agree with you Zlo and I also know (as you do) that Jacob does know his stuff and is a very good reliable source.....fellows have even been getting pre-released BIOS updates from him for thier Mobo's. Personally I think this is huge...the limitations that are now imposed upon us with OC'ing our GPU's (limited to Voltage without applying Volt Mods and buggering up the Warranty) will now be something more to twek...very nice...! As for buggering up the Card...did you guys not notice in the Evga Precision Voltage Screen their were upper n lower limits....I really believe Evga will have the required "Failsafes" and to incorporate this into Precision OC'ing Utility is excellent!!!
I'm looking forward to trying this out.....
Evga ....gotta like that Community n Support!
Firestrike Extreme: 21.452
MARK 11: 32.530
Voltage advice. encorp Overclocking, Tweaking and Benchmarking 3 November 20, 2008 11:49 PM
X48 Max Safe NB Voltage for 24/7 use? soapman72 Overclocking, Tweaking and Benchmarking 6 July 13, 2008 10:21 AM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
Overclocking question (Voltage) Wasza Overclocking, Tweaking and Benchmarking 2 January 22, 2008 11:28 AM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
