Before I go further, how much are you looking to spend on the GPU, this make a BIG difference in what we will suggest. Frankly you can't say "oh get nVidia" or "oh get ATi" because the end result will be the same with both brands in *MOST* cases. Only after sales support, performance per dollar, and warranties really matter now a days.
Originally Posted by Digikid Nvidia:
1.) Better looking graphics IMHO |
Nice one covering yourself with the IMHO, because I hate to break it to you, in a double blind test, you'll NEVER be able to tell the difference. The image quality in
most cases has been exactly the same between both brands for years now.
This isn't like comparing Pepsi to Coke-Cola, its like comparing Canadian Coke/Pepsi, to Mexican Coke/Pepsi, sure the ingredients used to make them might be slightly different but the resulting flavour will be the same.
Originally Posted by Digikid 4.) Better PhysX then HAVOK |
Perhaps, but how many games can you list that currently
use PhysX hardware acceleration? I can count it on one hand, most other games that currently use PhysX run the same regardless of weither its done on the CPU or GPU.
As for Linux, ATi's drivers have really improved in that field the last few years, very few issues with them now a days. I can't say which is better in Linux as I have not really done any intensive testing, suffice it to say I've never had any issues in recent times with either nVidia or ATi drivers in Linux.
