Old January 18, 2009, 07:33 AM
metalcore's Avatar
Default PHYSICS
:help: Hi all,
I currently own a BFG 9800GTX and have some questions regarding the physics acceleration.
Can I use a different card other than the 9800GTX that i have just to do physics and if so, what graphics card would be better?
Is there a model like 8600 gt or 8800 gt etc etc etc...that would be recommended to do just physics? I'm a little lost and don't want to spend a lot of money in a new card just to do physics. :)
Thanks in advance and have a great day!!
_____________________________________
-Cooler Master HAF X
-Asus Crosshair V
-SAPPHIRE 4890 " CROSSFIRE"
-Corsair H60
-OCZ VERTEX 2 60GB
-Phenom II 955 black
-wd velociraptor 300g sata hd
-wd caviar black 750gb sata hd
-wd caviar green 1000 sata hd
-8gb (2x4) GSKILL RAM
-lg blu-ray drive
-asus dvd/cd drive
-enermax galaxy 1000W PSU
-Kingston card reader
-Windows 7 Ultimate 64bit
Old January 18, 2009, 08:17 AM
Digikid's Avatar
I believe that you can use any 8xxx series Nvidia card for PhysX. Personally I would recommend either a 8800GT ( If you can find one I believe that they are EOL ) or a 9800GT.
NCIX.com - Buy EVGA E-GEFORCE 9800GT Superclocked 650MHZ 512MB 1.9GHZ 256BIT DDR3 Dual DVI-I HDTV Out Video Card - 512-P3-N976-AR In Canada. - EVGA 9800GT Superclocked - 163.00 after $10 Mail In Rebate
That will do ya.
Old January 18, 2009, 08:24 AM
Sniper's Avatar
Somebody should explain the benefit behind having a dedicated PhysX card & what it does exactly also as I'm even abit stumped by it myself haha. I will be getting new cards soon & may just get SLI while keeping one of my 8800GTX for a dedicated PhysX but I'd like to know more or if that would even be worth it?
Old January 18, 2009, 11:01 AM
Why do you want a dedicated card just for PhysX ? your 9800GTX should be able to handle PhysX and still get decent frame rates in your games - You should give it a try and test for yourself if your rates are decent for you given your resolution and quality settings, you might not even need to spend $$$ for nothing.
Old January 18, 2009, 11:34 AM
SugarJ's Avatar
I think Nvidia is hyping this Physx so that we will hang on to our older generation cards instead of reselling them to casual gamers. More business for them.
/end conspiracy theory
And apparently any 8 series and up card will work as your dedicated Physx card. I'd be tempted to get an 8500 or something like that.
Old January 18, 2009, 11:47 AM
In Mirrors Edge with PhysX on my cpu usage would be 50% (Core 0) and 90% (Core 1) and this is a C2D chip.
When I turned off PhsyX my cpu usage on both would usually stay around the 90-100% mark.
So no PhysX is not a marketing ploy and I'm sure with a dedicated GPU for PhysX I'd notice better performance out of my card with games.
Old January 18, 2009, 12:49 PM
MpG's Avatar
MpG MpG is offline
On a somewhat related note, is anyone aware of any studies showing what benefits Physx the most? i.e. if someone was looking at grabbing a cheap secondary card, which aspects are most important? Shader numbers? Shader speed? Memory speed? Memory capacity? How much would you give up going from a 8800GT to a 8600GT?
AMD & Havok Partner Up To Optimize Gaming Physics MAC Press Releases & Tech News 2 June 13, 2008 08:00 PM
Free Havok Physics Tools Hardware Canucks Press Releases & Tech News 0 June 2, 2008 05:17 PM
One Big Step for Physics? MpG Press Releases & Tech News 18 April 15, 2008 06:51 PM
AMD says GPU physics is dead until DirectX 11 Shadowmeph Press Releases & Tech News 12 November 26, 2007 06:53 PM
Has anyone tried Xfire + Physics Card...3x pci-e cards. qwerty Video Cards 5 November 5, 2007 04:46 PM
