Old January 15, 2009, 07:35 PM
KnSKranky's Avatar
Default It's January, it must be upgrade time!
Every January I do the same thing, wait for the price drops and then pull the trigger. Well this year, I landed a beauty. I picked up a Sapphire Radeon HD4870 512mb DDR5 for 249.99 at my local computer shop and I got the last one. A little price comparison revealed that this was cheaper than the etailers were offering it for by about 4-10 bucks.
I'm using Rivatuner to keep the fan at 45% and so far it idles at about 43C and loads at about 70-75C. I also like how it down clocks in 2D mode. IQ seems better plus colours are more vibrant than my 8800GT and am definitely seeing a performance boost at 16x10, my monitor's native rez.
Ta da! Here it is in all its glory.
Thanks for letting me indulge in a little hot air on this cold January day.
Cheers.
i5 3350P @ 3.1ghz
8192mb DDR3 Corsair Vengeance
Gigabyte GTX 660 2gb
Windows 8 Standard
Gigabyte GA-B75M-HD3
1TB SATA III
Realtek Onboard
NZXT Phantom 410 Gaming Case
Corsair 500w
Old January 15, 2009, 07:57 PM
Oversized Rooster's Avatar
Congrats on the 4870! A word of advice however - if you are going to OC it and play a game like GTA4, you may need to further increase the fan speed which will unfortunately make it loud.
I installed the Arctic Cooling Twin Turbo cooler on mine. I'm running 790 on the GPU and 4000 for the GDDR5. Idling at 40, loading at 58.
Watch out for the heat!
Main: Intel 2600K @ 4.8GHz | Gigabyte P67A-UD7-B3 | 16GB Corsair DDR3-2000 | 2 x 240GB Corsair Force 3 in RAID1 | 2 x 4TB Hitachi 7K4000 | 3 x 2TB WD Caviar Black | 3WARE 9650SE | Antec 1200 | Seasonic XP-860 Platinum | 2GB GTX 670 | 2 x 27" Asus VE278Q | Auzentech Prelude | Win7 Pro 64-bit
Old January 16, 2009, 02:33 AM
KnSKranky's Avatar
Thanks for the heads up, even at 45% I find the fan a little on the loud side. lol
i5 3350P @ 3.1ghz
Windows 8 Standard
1TB SATA III
Realtek Onboard
Corsair 500w
Old January 17, 2009, 10:44 AM
Exmortis's Avatar
Nice card, just returned mine for a ASUS Dark Knight version,k my PSU went out hard and took my vid card, mobo and ram with it. worked out for 30 morte bucks I have 1GB memopry and better cooler. 4870s rock been running one since release. Cannot wait to get my new rig up with my new Phenom II 940, but I am about to start a week of travel status with work, so will be a while.
Exmortis's System
Corsair 600T White
Asus P8Z68 Deluxe /Gen3
Intel i7-2600K w/Corsair H100
8GB Gskill DDR31600 cl7
MSI Lightning HD797 Lighting
OCZ Revo 3 240GB
OZC Vertex 3 240GB
WD Velocirapter 600GB
LG DVD burner
LG BluRay Burner
Sound Blaster XFi Titanium PCIe
Windows 7x64 Prem
Asus VE24/VE27/VE24
Logitech Z-5450 5.1 speakers
Corsair AX850 Gold PSU
Corsair K90 Keyboard
Logitech G5 Mouse
Old January 19, 2009, 04:11 AM
KnSKranky's Avatar
I did have a few crashes and blue screens with this beast so far. This is what I've done to try and correct this. Ran Driver sweeper and made sure all my old nVidia display files were gone.(found a few). Installed the latest nforce drivers. reinstalled cat 812s and set the fan speed to 50% in Overdrive. Ran a couple of benches and 3dMk06 gave me 11527 which seems low considering my 8800GT scored the same. Lightsmark gave me 145.4fps @16x10 which seems right. So far, I've found my 8800GT way more stable than this card.
i5 3350P @ 3.1ghz
Windows 8 Standard
1TB SATA III
Realtek Onboard
Corsair 500w
Upgrade time - what to keep?? Urotsukidoji New Builds 69 November 20, 2008 03:56 PM
It's time to upgrade... 3.0charlie New Builds 9 July 4, 2008 07:43 PM
Bad time to upgrade, need help. Matty D CPU's and Motherboards 12 May 4, 2008 09:08 AM
Time to Upgrade Again Beermaster CPU's and Motherboards 2 April 23, 2008 09:25 AM
time to upgrade monsterp CPU's and Motherboards 6 October 30, 2007 08:04 PM
