Old January 9, 2009, 02:08 PM
Default Advice Needed - GTX260 v GTX280
I'm building up a new system based on a i7 920 with a Gigabyte EX58-UD5 mobo.
I've been waiting about 2-weeks for the EVGA GTX260 Core216 superclocked to be in stock at my local store.
Now, I see they have the BFG GTX260 OCX Maxcore and the GTX280 OC all within about $40 of my original price and in stock today!
for specs, comparing clocks (main / shaders) + cores I guess:
EVGA 260 runs at 626MHz and 1350Mhz using 216cores and 896M Ram
BFG 260 runs at 655Mhz and 1404Mhz (260cores 896M ram)
BFG 280 615Mhz and 1350Mhz, but 240 cores and 1GB memory
So, the BFG 260 seems clocked faster than the EVGA 260 and even faster than the BFG 280. Will the 280 still be a better buy (slower, but more streams and memory). The first EVGA unit got some good reviews, so was my first choice.
Hopefully I can get some thoughts tonight, since I'll change my order and stop waiting.
Since I'm running a 22" LCD that does 1680x1050, maybe the questions irrelevant
Old January 9, 2009, 02:17 PM
magictorch's Avatar
I'd get the 280- the extra sp and bus width will beat-out higher clocks. Anyway you can just oc the 280 even higher and get some really nice frames.
Old January 9, 2009, 02:18 PM
Eagle Eye's Avatar
While I love my GTX280 if I were to do it all over again I'd get a GTX260 and the maxcore, check out the review here BFG GTX 260 OCX MAXCORE (216SP) 896MB Video Card Review it should help sway your decision.
Better frames with a GTX280 comes with a high CPU frequency hopefully that i7 rig won't be seeing stockclocks.
If only my GTX280 overclocked well its not a vanilla version for any other reason.
Where you buying from?
EE
PS. Welcome to the forums Steve
Old January 9, 2009, 02:29 PM
Thanks for the Welcome :)
Memory Express here in Edmonton.
Old January 9, 2009, 02:48 PM
geokilla's Avatar
I say GTX260 Core 216. More than enough for your 22" LCD monitor. Then just overclock it to max speeds.
Gtx260 price drop bxing day URGENT HELP NEEDED Cadence Video Cards 12 January 4, 2009 04:22 PM
Some advice needed please! D4ng3r Cases 5 December 9, 2008 11:45 AM
Advice needed on WC Jackquelegs Water Cooling 36 November 22, 2008 10:40 PM
Help, Need some advice on a upgrade from a GTX260 bushwickbill Video Cards 17 September 26, 2008 11:00 AM
Advice on loop needed ... Synth Water Cooling 8 May 9, 2008 05:31 AM
