A review at 3d guru shows the system load of several systems under full load with different graphics cards.
Radeon HD 4870 X2 and Crossfire review
HD 4870 .................... 334 watts
HD 4870x2 ................. 437 watts
this detailed thread shows the max power consumption of graphics cards alone. (by adding the wattage provided by the various connections and he max that can flow through these connections)
http://mark.zoomcities.com/images/gf...rchartby3d.png
HD 4870 .................... 130 watts (max)
HD 4870x2 ................. 264 watts (max)
so, using these numbers, i can roughly find the amount of power left to run the rest of the system. And if both match roughly i can continue.
4870 system - 4870 = 334-130 = 204 left for the system
4870x2 system - 4870x2 = 437- 264 = 173 left for system
ok, so ill just take the higher value to be safe.
add the power of the cards alone
4870 + 4870x2 = 130+264 = 394 watts
if im running with a 750 watt power supply at say, 80% efficiency at max load (my tx750)
that leaves (750*0.8)-394 = 600 - 394 = 206 watts left for the rest of the system.
so, does this seem right to you?
my system is similar to the one used in the 3dguru review, even the e8400, but mine is overclocked.
so, do you think i can run a 4870x2 and a 4870 in crossfire with my corsair tx750? rest of system specs in sig. keep in mind this is with the graphics cards and everything else at full load.
edit: just learned something about a psu efficiency, it should work from what i learned.
