Old December 27, 2008, 02:17 PM
Question does any1 have a palit radeon 4870 - measurements?
ive got a HP premade system, and the case is quite small, im looking to upgrade to a palit radeon 4870, but im not sure if it will fit, so i was just wondering if any1 had this card, and if you could tell me the measurements, cant seem to find them anywhere online! thanx
Old December 27, 2008, 02:25 PM
I don't recommend this for a few reasons
1) Heat problems in a small case
2) Actual fitment
3) Power requirements
Old December 27, 2008, 04:35 PM
Silvgearx's Avatar
Most video cards are no longer than 10.5 inches. But from what i know most high end ati cards are usually at 9'-10'
It would be a bit more helpful if you give more specs on your machine.
Old December 27, 2008, 04:42 PM
joeperson's Avatar
Palit Radeon HD4870 512MB Graphics Card Review
"When doing a size comparison to some of the cards that were and are presently in its price range we can see that the HD4870 is about 1” shorter than the 9800GTX but slightly longer than the HD4850 and older HD3870. Overall, the card is 9.5” long."
Go google.
Q6600 3.0GHZ (9x333) stockV | ATI 5850 | OCZ Platinum 4GB PC2-6400 DDR2 5.4.4.15 1.9V | Silverstone Raven RV01 | Gigabyte EP45-DS3R
Corsair Professional HX750W | Windows 7 | Crossbow mounted Xigmatek HDT-S1283 | LG W2242TQ-BF 22" | Samsung 2253BW 22"
Overclocking Palit Radeon 4850 Alwaysrun Video Cards 7 October 14, 2008 03:32 PM
Palit Radeon HD 4870 Sonic Dual, 1GB - Availlable yet?? Maiden69 Video Cards 0 October 8, 2008 10:08 AM
Palit Radeon HD 4870 Sonic Dual Edition CraigHf Video Cards 17 September 24, 2008 02:44 PM
