Old December 25, 2008, 06:43 PM
DRYJESUS's Avatar
Restricted Poster
Default Radeon HD 4870 Audio
I'm getting a 26" LCD TV tomorrow and obviously I want video and sound to output to the TV. I think I heard that the Radeon HD 4870 has audio support as long as you connect the audio from the motherboard to the card. The video card has 2 DVI outputs, but I believe that DVI doesn't carry sound. If I bought an HDMI-DVI cable and connect the DVI side the the video card and the HDMI side to the TV, would I get audio? Is there a difference if I use a HDMI DVI cable instead of using an HDMI cable with a DVI adapter?
Thanks in advance,
-Kevin
Old December 25, 2008, 07:44 PM
b1lk1's Avatar
You need the DVI - HDMI adapter that should have come with your card to get audio to the HDMI on your TV.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old December 25, 2008, 08:03 PM
Chilly's Avatar
If you need one of the DVI - HDMI connectors, I have a spare one from my 2nd 4870X2. Should work, PM me your info and I'll ship it out to you!
Old December 25, 2008, 08:34 PM
DRYJESUS's Avatar
Restricted Poster
So it would work even though the source is from a DVI output? Thanks a lot for your help!
Hahaha thanks, but I'm pretty sure there's one that came with my 4870 1GB I ordered as it came with your 4870X2.
About HIS Radeon HD 4870 1GB Kyure Video Cards 21 December 10, 2008 02:00 PM
FS: Sapphire Radeon 4870 512M ottoyu34 Buy/Sell & Trade 10 October 17, 2008 10:31 AM
[H] AMD ATI Radeon HD 4870 X2 CTA Reviews & Articles from the Web 0 September 11, 2008 03:49 PM
AMD Radeon HD 4870 X2 Pictured MAC Press Releases & Tech News 2 July 1, 2008 11:01 PM
