Old December 23, 2008, 01:25 PM
Default Physx on p45 boards?
Ok, I have an 8800gts640MB and a 9800gtx+512MB, if I bought an asus p5q pro will the mobo run a primary 9800gtx+ then use the 8800gts as a dedicated physx card in the 2nd pci e slot? Also, yes I realize it is a crossfire board and not sli but I'm not looking at trying to use it to run sli mode.
Now if I bought an nforce sli mobo would a 9800gtx+ run with an 8800gts(older g80, rev A3, 96 stream processes) in sli mode?
Just trying to use up the 8800gts before I give up and sell it off for a huge loss.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use FX8350 Stock GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old December 23, 2008, 01:34 PM
Chilly's Avatar
You can't mix and match SLi, regardless of the chipset its installed on. Only ATi's cards can do that(mix and match) currently.
As for PhysX, YES, you can on the P5Q Pro. Just ensure you install the 9800GTX+ in the top slot and the 8800GTS in the bottom slot. Install the latest nVidia drivers(180.48), and enable "Hardware Acceleration" in the PhysX area of the nVidia control panel. If I can get a hold of some different nVidia cards(I'll try my best, I live in a sea of red), I'll throw up a guide on how to do it.
Old December 23, 2008, 01:48 PM
bojangles's Avatar
As Chilly said, YES, you can run PhysX on the P5Q Pro. You do not need to run an SLI connector (well duh since it's a XFire board). Set the 9800 as primary and on the PhysX tab set your default to the secondary.
Old December 23, 2008, 02:11 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
I agree....YES you can. You don`t need the SLI bridge installed.
Old December 23, 2008, 02:45 PM
Sorry to go OT, is there any noticeable performance increases in games or something.
Old December 23, 2008, 04:27 PM
Thanks for the info from all, glad I can use the old card after all.
A few more questions, If I was to keep my am2 cpu and went with am2 790fx mobo would the 8800gts still be able to be used for 2nd physx card? I.ve been looking at am2 sli boards and the price seems alot higher than asus p5q pro. Basically I'll be looking at the specials on boxing day and was wondering if anyone has suggestions for a solid am2+ sli board or am2+ 790fx chipset boards to keep a look out for? If I have to bite the bullet and go intel I will if there are some good deals but would rather stay with amd for now to cut cost and just get an am2+ SLI or CF mobo.
Old December 23, 2008, 06:14 PM
bojangles's Avatar
From what I've heard, the next generation games (coming out soon) will highly benefit from this.
My new rig before i swapped boards fyshawk Case Mods, Worklog & Gallery 0 October 5, 2008 03:43 AM
Get Physx on your lappy! Cheator Video Cards 3 August 16, 2008 07:53 PM
New PhysX driver burebista Video Cards 19 August 12, 2008 06:23 AM
AMD 570 vs AMD 770 AM2 boards Flintblade CPU's and Motherboards 1 February 21, 2008 03:14 AM
SMART boards. Mysteryous O/S's, Drivers & General Software 2 December 16, 2007 10:06 PM
