Old December 6, 2008, 01:04 PM
werty316's Avatar
Default Replace stock white pads with Sekisui?
I am thinking of replacing the stock white thermal pads that are on my video card so I was wondering if it'd be worth it to replace these stock pads with Sekisui thermal tape or should I just stick with the stock thermal pads?
The white pads I am speaking of are like the ones that are highlighted in the attached pic:
Thanks guys
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old December 6, 2008, 01:28 PM
sswilson's Avatar
If you look at the compresson on the pads you'll probably find that the heatsink has a slight gap between it and the memory chips. I wouldn't trust the thermal tape to make a good contact in that kind of "fixed" installation.
