Old December 3, 2008, 06:28 PM
zlojack's Avatar
Default Help me troubleshoot an 8800 GTS
I've just received an 8800 GTS 512 that I got in a trade.
System specs are as follows:
Asus P5K
4 GB Generic RAM @ 800 4-4-4-12
CoolerMaster Extreme Power 650W
EVGA 8800 GTS
This is a backup rig and I was running a Sapphire 3670 which was is just fine (indicating that the PCIE slots are fine)
I proceeded to uninstall Catalyst, remove all drivers in safe mode with Driver Sweeper and then power down.
I then turned off the PSU and proceeded to remove the 3670 from the case and install the 8800 GTS.
I plugged in the PCIE power connector and made sure everything was well connected and then hit power.
Seems like there's no signal going from the card to the monitor. I even got the Windows startup sound, but no image on the screen.
The fan spins.
Any ideas or am I SOL?
(I got this card in a trade for some RAM, so I hope it's not DOA)
Old December 3, 2008, 06:50 PM
reset jumper on the mobo is your friend, or do a full bios wipe
CPU: Dual QX9775
MOBO:D5400xs
Ram: 4GB FB-Dimm
PSU:Koolance 1300 Watt
Graphics: Tri sli XXX GTX280 XXX
HDD:2 Supertalent SSD
LCD:24IN Samsung wide
CASE:TT Armor
Danger Den WC Setup
4 Pelts 226Watt
Old December 3, 2008, 06:51 PM
"Quote This..."
my p5k did the same thing when I switched from a 4850 to gtx 260.
Unplug the power, reset the cmos.
Old December 3, 2008, 07:03 PM
zlojack's Avatar
Ok...I'll try that.
Thanks!
Old December 3, 2008, 07:43 PM
zlojack's Avatar
Alright
I've got it up and running, but in the bottom 4x slot
My other card runs in the top slot, so I'm obviously doing something wrong. I reset the CMOS by taking out the battery and I updated to the most recent bios from Asus for the board.
I can't imagine the 16x slot is damaged or the other card wouldn't work there, right?
Old December 3, 2008, 07:50 PM
sswilson's Avatar
Did you run the card from the 4X slot first (boot into windows), and then reset cmos / move the card back to X16?
Sounds like it might be the same kind of issue I keep PCI cards around for...
How about setting the bios to default/optimum settings?
Old December 3, 2008, 07:56 PM
zlojack's Avatar
Alright.
I'm in Windows with the card in the 4x slot.
So now that I've got into Windows and installed the drivers, I should reset the CMOS again?
Bios is all at default settings.
Old December 3, 2008, 08:03 PM
sswilson's Avatar
Try shutting down, resetting cmos, moving the card, then booting back into windows.
Old December 3, 2008, 08:35 PM
zlojack's Avatar
Ok...no luck there either.
I even left the CMOS battery out while I walked the damn dog.
It's funny...the fan spins up to 100% and just sticks there.
In the 4x slot it spins up for a few seconds then backs off.
Old December 3, 2008, 08:39 PM
sswilson's Avatar
hrmmmm......
Asus P5K Deluxe - no video display (resolved)
Sounds pretty fishy to me, but you're running out of options......
