Old December 3, 2008, 04:17 PM
Default recommended brand + overclocked models for HD 4870 x2
i was just wondering which retailer brand i should be going with for a HD 4870 x2 card. i WILL be removing the stock heatsink(i've heard these cards are a mess when to comes to temp and noise), so a mod-friendly warranty would be nice. :)
also, i've seen some overclocked hd4870x2 cards out there. I can't think of any at the moment, but is anyone aware of such a card that gives an appreciable boost in performance? also, how hard would it be to do such an overclock yourself(on a x58 chipset)?
Old December 5, 2008, 08:09 AM
Cranky's Avatar
When it comes to overclocking, I wouldn't bother. I'm running all my games at 1920x1200 without a hitch. and if you manually control the fan in CCC, heat isn't much of an issue. I just finished looking through the warranty information of several brands, and none of them seem to cover modding.
Asus P5K Deluxe / Intel Core2Quad Q9550@8x425@3400mhz(1.225v) / Arctic Cooling Freezer 7 Pro / 4Gigs DDR2 1066mhz(5-5-5-15) Corsair Dominator / Diamond HD4870x2 / Asus Xonar / WD Raptor 74gb / Hitachi 160GB / Antec Quattro 850w / Logitech Z-680 5.1 / Dell Ultrasharp 24" / 2 LG Optical Drives / Vista Ultimate 32bit / A tower that's been drilled, cut, and bent to fit all of my fans
Old December 5, 2008, 08:56 AM
As hard as this is for me, forget the 4870x2. Get GTX280 and save some cash. Better warranty and more modding-friendly brands mean a better experience for you.
Old December 5, 2008, 10:08 AM
CMetaphor's Avatar
Quadfather
Visiontek comes with a lifetime warranty
Old December 5, 2008, 10:23 AM
Cranky's Avatar
True, but will not warranty, if any damages results while modded.
Old December 5, 2008, 10:28 AM
vinister's Avatar
Not so true, they warrantied 2 of my 3870's, both had been volt-modded and were killed by folding at 1Ghz 24/7 at high voltage. One of them even had a backplate that I had cut in half to fit it in the case.
They returned me 2 brand new 3870's of a much newer revision, no questions asked. It did, however, take about 3 months.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old December 5, 2008, 11:21 AM
Cranky's Avatar
Huh, Well I guess they need to be a little more clear in their warranty statement.
