Old December 1, 2008, 11:37 PM
werty316's Avatar
Default Cleaning video card ram chips
I used 70% isopropyl to clean the ram chips on a video card however it didn't seem to do the trick as the ramsinks I installed aren't sticking on very well.
Would a higher percentage of isopropyl be more effective?
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old December 1, 2008, 11:40 PM
Neolithium_Wpg's Avatar
Once you clean them off with the alcohol, use an eraser on them (Edit - GENTLY use), it helps take the greasy film off and lets them stick properly.
Dell XPS8700 | Asus x101ch | iPhone 5 (iOS7)
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
Old December 2, 2008, 01:15 AM
Cptn Vortex's Avatar
99% and use a microfibre cloth, similar to what you use to clean sunglasses. I used an old Oakley one I had lying about and it cleaned those chips like new.
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.2GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
Old December 2, 2008, 07:45 AM
werty316's Avatar
Alrighty guys, thanks for your advice
Old December 2, 2008, 12:39 PM
Eagle Eye's Avatar
I can't find 99% isopropyl alcohol anywhere, most drugstores only sell 70% these days.
Old December 2, 2008, 12:48 PM
SugarJ's Avatar
I got mine at London Drugs. I'm not sure if they are back east or not.
Old December 2, 2008, 12:53 PM
bojangles's Avatar
I think it's over-the-counter now, but if you explain exactly what it's for (cleaning computer chips, etc.), they might give some to you.
Old December 2, 2008, 01:12 PM
Chilly's Avatar
I found some just the other day at a Shoppers Drug Mart around the corner from me, and I'm in the GTA, try them. Cheap no name generic stuff.
Old December 2, 2008, 01:16 PM
I know all over Winnipeg you actually have to ask the Pharmacist for the 90+% stuff. Around here for some reason most inquire what it's fore but it gave me a nice 20 minute computer conversation with a good looking one ;)
-Author Unknown
sswilson's Avatar
Yep, bought mine off the shelf at Wally Mart.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
