Old December 1, 2008, 11:08 AM
biff's Avatar
Default Thinking of next vid card
I have a Asus EN8800GT TOP that is volt modded/WCed, running the core/shaders at 850/2000. I'm really starting to notice the sluggishness running COD4 so I turned the res down to 1280x800 (IIRC) from my native 1920x1200 to smooth it out... not bad but still not perfect.
So I'm tossing up between the gtx 260 and 280. The 280 doesn't seem to bench faster by any great margin and maybe that gap could be lessened by a good OC on a 260? I'm not in any big hurry so I can wait if there is some latest/greatest card coming down the pipeline soon.
I want to stay with nVidia, not for fanboy reasons but I have a second video card to run a couple aux. monitors so if I went with ATI I'd have to change that card too. I imagine there would be driver issues abound trying to run ATI and nVidia on the same machine. I'm also not interested in SLI.
The 260-216 is in the range of what I want to spend. I would spend the $$$ on a 280 if it was leaps and bounds better but that doesn't seen to be the case so it seems like a bit of a waste at almost twice as much. For that matter is a 260-216 enough of a jump over my 8800GT to make that card worth it?
Any advice on what I should do?
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old December 1, 2008, 11:32 AM
260-216 is a good way to go. It performs well and at a decent cost. I don't know about mixing ati and nvidia but I'm sure someone else will. If you do go nvidia, the 260-216 is the card I would go with.
Old December 1, 2008, 11:40 AM
3.0charlie's Avatar
Forget about running ATI / nVidia on the same machine.
+1 for the 260-216. But if you can find a used 280, jump on it. That card is a monster.
Hydro-Quebec is salivating...
Old December 1, 2008, 12:38 PM
"Quote This..."
+2 for 260-216.
Old December 1, 2008, 03:34 PM
rjbarker's Avatar
GTX 260 (216) SC is a great Card, although I had only the 192 Core FTW version to compare to both Single 280 and SLI 280, I believe for a single Card solution try and find a deal on a 280..as stated, it really is a monster and the gains @ 1920 x 1200 Res are appreciable. With that said, the 216 Core is a very good Card that runs considerably cooler than the 280...
6 to one half a dozen the other..really depends upon what kind of deal you can find and what you're willing to spend.
A few months ago I was able to get a 280 SSC Version from DC for $500 (total w Taxes and just recieved my $40 MIR last week), then I found the same deal at NCIX for around the same cost. The prices are quite high right now and a 216 Core is likely more justifiable!
Either way..you will be happy!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old December 1, 2008, 05:58 PM
magictorch's Avatar
Pretty sure there's a 280 for sale for $400 I'd go for that or wait until January-Feb when the much anticipated die shrinks of the 260 show-up.
Old December 1, 2008, 09:07 PM
biff's Avatar
I hadn't done a lot price comparing but I saw a 260-216 for $308 and the 280's I was seeing were mid 5's, but I did some more searching and found them in the mid 4's so if there is that much of a difference in the higher resolutions then the 280 makes the most sense. BTW Where's that 280 for $400?
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old December 2, 2008, 07:48 PM
Dashock's Avatar
Getting raped lately on the new projects im thinking of upgrading my 8800GT i think theres some new monster cards coming out from Nvidia so wait and see if the existing card prices go down but i must say i was thinking about getting the 260-216 cores myself.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old December 2, 2008, 08:35 PM
Cranky's Avatar
Hmmm, I don't know if the 260-216 is really worth it over the original 260. When you check out the benchmarks you do see, grant you, that the 260-216 does an average of "up to" 10fps over the 260 in 1920x1200 resolutions but when you are already doing 50+ fps why does it matter? I'm seeing the 260 vanilla at NCIX for $275.00
NCIX.com - Buy EVGA E-GEFORCE GTX 260 576MHZ 896MB 2.0GHZ GDDR3 PCI-E Dual DVI-I HDCP HDTV Out Video Card - 896-P3-1260-AR In Canada.
Here is a review of the 260-216 card, you can decide for yourself:
GeForce GTX 260 reloaded vs. the Radeon HD 4870 1GB - The Tech Report - Page 1
Asus P5K Deluxe / Intel Core2Quad Q9550@8x425@3400mhz(1.225v) / Arctic Cooling Freezer 7 Pro / 4Gigs DDR2 1066mhz(5-5-5-15) Corsair Dominator / Diamond HD4870x2 / Asus Xonar / WD Raptor 74gb / Hitachi 160GB / Antec Quattro 850w / Logitech Z-680 5.1 / Dell Ultrasharp 24" / 2 LG Optical Drives / Vista Ultimate 32bit / A tower that's been drilled, cut, and bent to fit all of my fans
Old December 2, 2008, 08:41 PM
rjbarker's Avatar
Just a reminder, thats $460 CDN total brand new c/w Lifetime Warrenty...used Evga products are not Warrantied. Also, the 1st Card was the noted price, then the prices went up significantly for about a month, then the same deal was available on NCIX.....just keep a close eye on the prices!
MARK 11: 32.530
