Old November 24, 2008, 10:47 PM
Eagle Eye's Avatar
Default High Pitched whine + GTX280
As stated in the title my GTX280 is emitting a high pitched whine when under load is this normal or should be some cause for concern?
I have done some research on the web and no one has a solid answer to the problem other than suggesting to RMA the video card. I was hoping if any other owners of the GTX280 might be able to tell me if they have experienced the same issue and what if anything they've done about it.
Regards,
EE
Old November 24, 2008, 10:53 PM
Its normal and no a RMA will not fix it.
Old November 24, 2008, 11:05 PM
Phobia's Avatar
my 9800gx2 just did that.. i was folding. as soon as i stopped folding the noise stopped
(whitty saying to be plagiarized at a later date)
Old November 24, 2008, 11:20 PM
Eagle Eye's Avatar
Exactly Phobia folding is probably when its at its worst.
@ Enaberif I figured so, and I am without a proper backup gpu so thats out of the question.
Thanks very much guys
EE
Old November 25, 2008, 12:06 AM
reaverclan's Avatar
mine does that when crysis starts up then it stops when it loads the map completely, its normal. same for any graphic intense game, does not happen in normal pc usage.
Old November 25, 2008, 12:09 AM
This is an issue that has existed since the days of the 8800GTX and perhaps earlier.
Old November 25, 2008, 05:42 AM
Chilly's Avatar
Yep, my 8800 Ultra when I still owned it did the exact same thing, got me all worried at first like you too till I found out its a common issue.
Old November 25, 2008, 06:24 AM
3.0charlie's Avatar
Both my 280s did that noise under load from folding. It's annoying I agree...
Hydro-Quebec is salivating...
Old November 25, 2008, 06:47 AM
The noise is present with my GTX 280 and was present with my 8800 GTS 512 while folding
Back up - Ebay (Inik1) or Heatware
Old November 25, 2008, 06:55 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
If you have the noise while running a game, I am going to recommend you enable V Sync.
