  #21 (permalink)
Old November 25, 2008, 01:16 PM
odis172's Avatar
My evga akimbo 8800gt 512 does it. It seems to be attched to the shaderclock, as the shaders are stock oc'd to 1780, and when folding it whines like a mofo. Using rivatuner to adjust the shaderclock, the pitch of the noise decreases as i turn down the shaders, and stops when it hits 1520. I havent noticed it when gaming, as my sound is usually pretty loud.
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
  #22 (permalink)
Old November 25, 2008, 02:33 PM
Eagle Eye's Avatar
Thanks guys for all the help!! Its sits a little better now knowing I am not the only who experiences this.
EE
  #23 (permalink)
Old November 25, 2008, 10:19 PM
That's the sound of the card sucking up all the juice from your PSU.......Those cards require quite a lot of amperage under full load :D :D :D
All kidding aside, the first thing I thought when I heard this sound for the first time on my 8800GTS 320MB, was probably weak caps, since the sound come from the area with the large caps...
  #24 (permalink)
Old November 26, 2008, 12:08 AM
Dashock's Avatar
Mine squeals as well but only on folding and the pitch gets louder as the overclock gets higher. Playing games on the other hand i do not notice a pitch but then again i beel playing a lot of Red Alert lately and the frames are capped pretty low so i dont think it would give the opportunity to squeal. But i will admit it is annoooying, i am getting used to it though. Yea as Odis said i think it only has to do with shader clock cause you can change the tune of the whine as you increase or decrease shader clock.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
