Old November 17, 2008, 09:47 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default BFG GTX 260 OCX MAXCORE Review Comment Thread
I am gradually making my way through the pile of GPUs which built up in the last few weeks so today there is another review for you: that of the BFG GTX 260 OCX MAXCORE. This is a GTX 260 card with 216SPs and is overclocked to 'till it begs for mercy.
You can check out the review here: BFG GTX 260 OCX MAXCORE (216SP) 896MB Video Card Review
Please us this thread for all your questions and comments.
Old November 17, 2008, 10:00 PM
"we would recommend you look at investing in a god 700W power supply."
maybe first comment
Maybe if its possible do a ppd for folding as another benchmark
Intel Core 2 Duo e8400 @ 3.8GHz
Mushkin Ascent 1x2gb
Asus P5N-D
BFG Geforce 8800GT OC SLI (folding issues...)
WD 500GB
NZXT Apollo
OCZ Vendetta 2 w/ Bolt-thru kit +Scythe S-Flex F
Syncmaster T220, Razer Deathadder, Lycosa Mirror Edition, X-240 speakers
Old November 17, 2008, 10:01 PM
chouchou's Avatar
Think a Q6600 Run at 3.2 paired with this would run on a hx620w?
Old November 17, 2008, 10:10 PM
I run an oc'ed GTX 280 with a Q6600 @ 3.2 without any issue ;)
Back up - Ebay (Inikurmoma) or Heatware
Old November 17, 2008, 10:36 PM
encorp's Avatar
There is a typo in the memory speed of the 9800GTX+
240mhz? lol slow card!
Great review so far btw; one of the first things I looked for was whether you guys used the i7 set up. I guess SKY dosn't have it or it went back?
Any idea when we'll see a single i7 platform to test video cards from ATI and Nvidia?
DISCLAIMER: The views and opinions expressed in the immediately preceding post are those of encorp and do not reflect the views and/or opinions of family, friends, or anyone remotely associated with encorp unless explicitly stated. encorp does not make any warranty, express or implied, or assumes any liability or responsibility for the quality, factuality or use of information in the immediately preceding post.
Old November 18, 2008, 05:54 AM
SKYMTL's Avatar
I'm not going to use an i7 for the next while. The first thing that comes will be a new test suite and then in about 2-3 months an i7 setup.
Old November 18, 2008, 05:57 AM
SKYMTL's Avatar
Yes, it will. I recommend a 700W PSU because there are many people out there who see "700W" and then think "well, it will run fine on a 600W". If I put 600W, there would be people thinking it will run ok on a 500W...which it probably won't.
Old November 18, 2008, 06:04 AM
burebista's Avatar
Thanks SKYMTL, as usual a very good review for a dam good GPU.
Just a question sorta offtopic
If you are running this card with an overclocked quad core processor, we would recommend you look at investing in a good 700W power supply.
Why? If you pull 340W from the wall and 270W from PSU why do you need a 700W PSU?
LE: I see your reason, but is enough to say that a good brand 500-550W PSU is enough for this and not a craptacular 700W PSU.
BTW, and if we speak about PSU's I really miss your PSU reviews...
Old November 18, 2008, 06:20 AM
lemonlime's Avatar
Hardware Canucks Reviewer
Great review, SKY
In regards to the PSU recommendation, not everyone runs Corsair, PCP&C and other high quality PSUs. I think the blanket 700W recommendation was a good one that won't steer anyone in the wrong direction--especially the less than savvy crowd.
Old November 18, 2008, 07:00 AM
SKYMTL's Avatar
Why? If you pull 340W from the wall and 270W from PSU why do you need a 700W PSU?...
This is a VERY good point and I am glad you brought it up. The reason for the recommendation is that the test I run for power consumption is VERY GPU intensive while the CPU is pretty much left at idle. As a matter of fact, if I look at the CPU useage log after the test, the CPU never goes above 5% on any of the cores. I do this so the CPU does not affect the overall power consumption figures and we can see a clearer picture of which GPU requires the most power.
I have also been thinking of adding a "worst case" scenario consumption test much like I did in the PSU reviews. Bacially running the Batch Size Test on the GPU while running OCCT in the background on the CPU. This would give a clearer indication of the power consumption in a GPU-intensive game that uses the CPU for physics calculations.
A good example of this would be in Crysis Warhead where I have routinely seen power consumption above 575W from the wall using the EVGA GTX 260 Core 216 Superclocked card.
They will be back but I am presently building the new PSU and GPU test system which will center around an X58 / i7 combo. The first PSU tested on it should be a little surprise from Corsair.
