Old May 8, 2007, 03:04 PM
Misoprostol
Guest
Posts: n/a
Default possible to run SLI with an 8800GTS 640 and an 8800GTS 320?
Anyone know if it's possible to run these two cards in SLI? I'm kinda tempted to try it, but I'd have to pull my water cooling stuff off my GTS640, and take my GTS320 out of its package. Is anyone else as curious as I am, or does anyone know the answer?
Old May 8, 2007, 06:43 PM
werty316's Avatar
As far as I know it should since both share the same core; the only problem is the memory buffer will only go as high as the card with the lowest amount of memory which is 320MB.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old May 8, 2007, 06:45 PM
b1lk1's Avatar
What he said.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old May 8, 2007, 07:04 PM
Babrbarossa's Avatar
I asked this question a couple of months ago- I'me curious to see what happens.
Old May 8, 2007, 09:36 PM
Patriote's Avatar
Do we have a kind of Worklog\Testing session here ?
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
Old May 9, 2007, 10:18 AM
xShadowAero's Avatar
Default Yes
Yes you can, although they say you need to use Coolbits when your cards have different memory sizes. Must be the same GPU, do not have to be the same vendor or clock (since rev 80.x driver).
FAQ
Old May 9, 2007, 01:07 PM
Misoprostol
Guest
Posts: n/a
It didn't work.
Test bed:
eVGA 680i
Intel Pentium D 805
2x 256MB cheapo RAM
el cheapo Maxtor 120GB SATA hard drive
BFG 8800 GTS OC 640MB
BFG 8800 GTS OC 320MB
Windows XP Service Pack 2
Latest drivers off nVidia web site
Random 600W SLI power supply.
SLI is not available as an option in the driver control panel
Old May 9, 2007, 01:21 PM
Misoprostol
Guest
Posts: n/a
Update:
Talked to BFG tech support and according to them it should work. I'll update with more details once I have them. Hopefully I will have some time play around with it tonight.
Update #2:
Talked to eVGA. They say there's no way that will work.
Update #3:
Talked to XFX. They say that some people have gotten it working, and there are setting in nTune, but they won't tell me where they are.
Some random reading has produced some evidence that I may need to have the card with less memory in the top slot. I will try this when I get home.
Old May 9, 2007, 06:52 PM
Patriote's Avatar
Everyones saying different things huh ?
XFX is probably right. There has to be some ppls out there that got it to work. Let us know how things are going!
- Asus P8Z68-V PRO
- Noctua NH-D14
Old May 10, 2007, 09:00 PM
Misoprostol
Guest
Posts: n/a
tried flashing the 640MB card to the bios of the 320mb card, tried both slots. SLI is not detected :(
8800gts 512mb miggs78 Video Cards 0 March 9, 2008 07:40 AM
Which 8800gts 512 or gt? dboulay79 Video Cards 13 February 21, 2008 01:33 PM
8800GTS 640mb darkorb Video Cards 4 November 10, 2007 02:57 PM
Can i use a 8800GTS 640 to F@H? Apollo4g HardwareCanucks F@H Team 1 August 21, 2007 05:20 PM
Gaming Shootout: HD 2900xt vs 8800gts vs 8800gts: X-Bit labs Babrbarossa Reviews & Articles from the Web 12 May 29, 2007 04:08 AM
