Old November 15, 2008, 08:14 PM
chouchou's Avatar
Default BFG vs eVGA
I'm purchasing a new Gtx 260 Core 216.
I'm stuck between these two. They both offer Far Cry with registration and Lifetime warranty.
Who would you go with?
thanks. on :)
Old November 15, 2008, 08:18 PM
sswilson's Avatar
Any info available on the `net about the cooling on each one? That'd be what I based my decision on.
Old November 15, 2008, 08:24 PM
Xilikon's Avatar
I would go EVGA on the fact that I can use a aftermarket cooling solution without voiding the warranty. However, if you prefer using the stock cooler, either one is great.
Xilikon - Team 33
Proud to be [H]ard !
Old November 15, 2008, 08:25 PM
matsta31's Avatar
EVGA has step up and let you change the cooling solution without voiding your warrenty.
BFG has an RMA dept in Québec !
Sold hardware again.....
Currently using WHS hardware....
Old November 15, 2008, 08:26 PM
chouchou's Avatar
this is the specific one im looking to get from eVGA
NCIX.com - Buy EVGA E-GEFORCE GTX 260 Core 216 SC 626MHZ 896MB 2.1GHZ GDDR3 PCI-E 2XDVI-I HDCP HDTV Out Video Card - 896-P3-1267-AR In Canada.
any info on the stock cooler on that? and will a q6600 bottleneck it?
Old November 15, 2008, 09:10 PM
magictorch's Avatar
I would go EVGA too, but I'm not sure its a good idea to get that card just yet. I would wait a few weeks for the GTX270. It will likely be the same price. You'll need to be quick as there probably wont be enough for the demand initially-bit like the 8800GT at launch last year. My guess is the GTX 290/270 will retail late November early December as the 55nm quadra cards are about now.
Old November 15, 2008, 09:13 PM
geokilla's Avatar
Both of them are very good companies. Remember that BFG's warranty is broken once the graphic card is overclocked, but I don't think they can detect whether your card has been overclocked or not....
If they're both the same price, I'd say EVGA. Otherwise, either is fine. Oh, and don't forget XFX.
Old November 15, 2008, 09:39 PM
chouchou's Avatar
XFX doesn't have a great line of Maxcore 260's. If iw as going 280 id probably go XFX. Anymore information on the gtx 270's?
Old November 15, 2008, 09:46 PM
reaverclan's Avatar
lol damb u Nvidia i just bought my GTX 280 SSC and its on the way all well it will be much improvement to a 8800GT.
Old November 15, 2008, 11:11 PM
rjbarker's Avatar
Stock cooling is Stock cooling...take the Evga for:
1. SUPPORT - check out Evga.com
2. Step -up
3. Lifetime Warranty whether you Overclock or not
4. available Water cooling solutions (although you won't need it)
Personally, I had the GTX 260 FTW Edition prior to my 280's, the thing Overclocked like a banchee right out of the box (720 / 1458/ 1250) and the Temps never got over 62c playing Crysis....great Cards!!!
As Magic Torch mentioned, the 270 / 290's MAY be out in the next few weeks, so the question is, is it worht waiting?....I really don't think they will be the "same price", new release Card = more $$$, but the decision is yours....
Firestrike Extreme: 21.452
MARK 11: 32.530
