Old November 4, 2008, 05:09 PM
CMetaphor's Avatar
Quadfather
While testing my TH2Go I found that with the onboard Crossfire enabled on the 4870X2 both monitor outputs were cloned. Now if i could only figure out how to disable the Xfire (disabling catalyst AI doesnt work).
@Babrbarossa: That's one HDMI and one Display Port.
Old November 4, 2008, 05:32 PM
lemonlime's Avatar
Hardware Canucks Reviewer
Hey for a dual GPU card, I think a 3-slot cooling solution is not a bad idea. I would have preferred a cooling solution that directs all exhaust out of those two extra slots though.
Old November 4, 2008, 05:37 PM
Babrbarossa's Avatar
Originally Posted by Killswitch View Post
You meant VGA instead of AGP right?
hee hee - yeah
Old November 4, 2008, 05:58 PM
Eagle Eye's Avatar
I totally agree why are we not seeing this more I really wonder why some of the fastest and hottest GPUs are still pushing hot air back into a case rather than out, but I guess with all the display connectors it wasn't a feasible design.
Old November 4, 2008, 06:22 PM
Originally Posted by sswilson View Post
The output configuration does bring up a question for me though.... Can anybody with an X2 card confirm if they can run two monitors off of it, or is that not possible because of the internal crossfire?
Yep, possible, and on the ASUS 3870x2 TOP cards you can run four monitors on a single card. I run HDMI-out to HDTV, and dell 30 inch off 4870x2.
Old November 4, 2008, 06:25 PM
sswilson's Avatar
Originally Posted by cadaveca View Post
Yep, possible, and on the ASUS TOP cards you can run four monitors on a single card. I run HDMI-out to HDTV, and dell 30 inch off 4870x2.
Yes, but are they simply cloned (as per the following quote) or can you spread the desktop over it?
Old November 4, 2008, 06:28 PM
yes, spread desktop, clone, and then you can use hyrdavision to get many desktops. Once you enable the second display, yes, it is cloned, but if you right-click the right spot in CCC, you can extend the desktop. I have to have the HDTV as main monitor, extended desktop, in order to play blurays with both connected...clone doesn't allow display on either monitor.
His issue is problaby due to use the matrox unit, i do it all in CCC, even running 3 monitors stretched across 2 cards.
