Old November 1, 2008, 11:10 AM
sswilson's Avatar
Default Looking for a good primer on vid card settings & display issues
Ok, finally going to take the plunge and try to expand my knowledge of vid card settings/issues so I'm looking for a decent on-line explaination of the different settings, what they do, as well as issues such as "tearing". I've never been a heavy FPS gamer, so have pretty well stuck with whatever settings the game gives me, although I have mucked about a bit with forcing settings like AA in the drivers.
I'm trying my google skills ATM, but if somebody has a good bookmark handy I'd appreciate it.
What I'm mainly interested in is a site with pictures of the various issues that can be encounted, with a description of what can be done to fix them.
Thanks in advance.
Old November 1, 2008, 11:18 AM
"Quote This..."
Try this, along with the 'see also' topics.
3D computer graphics - Wikipedia, the free encyclopedia
I am a 3d programmer, so if you have any specific questions ask away.
Old November 1, 2008, 11:27 AM
sswilson's Avatar
Thanks, I had a quick look at Wikipedia, but of course the subject matter is pretty broad. :)
The specific issue I'm looking for (other than needing to better inform myself on general terms) is the screen having a horizontal line (or more than one) which seems to split the screen a bit. I was wondering if the Vsync was the setting I should be looking at for that.
Old November 1, 2008, 11:43 AM
"Quote This..."
Yes, that is called tearing.
Your vid card has a frame buffer, a section of the vid card memory holding the individual frame image. Once an individual frame has been fully processed it gets written to that frame buffer. your vid cards framerate is how many times per second it is writing completed frames into that memory.
Your monitor does not interact with your vid card other than to read from this frame buffer every time it does a refresh (refresh rate). Tearing occurs whenever your vid card reads a frame that is in the process of being overwritten with a newer frame. This means it is out of sync. vsync is nothing more than matching your vid cards output with the refresh rate of your monitor ensuring that no partially written frames get read.
Old November 1, 2008, 11:48 AM
sswilson's Avatar
Ok, then since my LCD monitor has a maximum refresh of 60, should I force this on or off to try to fix the tearing?
Old November 1, 2008, 11:55 AM
"Quote This..."
To me it depends on the game and the average framerate you are getting.
Some dumb assed games will drop your framerate to 30 as soon as it dips below 60. Very poor vsync. Games like unreal 3 engine based, FC2 and fallout will disconnect vsync when it hits 59 or lower as you will not get tearing anyhow. try it and see.
Old November 2, 2008, 10:21 AM
yeah tearing genreally only happens in FPS but sometimes do happen in other types of games teaing happens when your card is rendering the game too fast.... Generally games generate frames in lines, so when your card renders over the line twice is creates a tear Vertical Sync prevents this by lowering the speed of FPS of your card generates. But as Squeetard said some games screw up on this option.
