Originally Posted by rob123 hello all.
just put in one of those bfg 8800gt oc cards.
found that the idle is getting to 64C. a tad high for such a big case. i have fans nearly everywhere.
i have used ntune to force the fan to run at 55%. this brings the temp down to 53C. not perfect but better than idling at 64C.
i can seem to figure how to use ntune to create a rule to make 55% the minimum speed. need to know because when i restart the system it goes back to the default.
also today i will be puting together a sli system with 2 of these and a quad core processor. dont want heat ot become a major issue.
thx
rob123 |
As stated by many other users its pretty clear 8800GT suffers from a poor single slot cooling design, I'd looked into an aftermarket cooler.
Possible options out there are:
EVGA | Products Excellent cooling potential quiet, but limited only to the 8800GT video.
Arctic Cooling This one goes with little explanation other than that lots of people have this cooler, don't forget that it still needs a fan to achieve those awesome temps.
Arctic Cooling Excellent cooling in a sleeker package, some people have complained about the fans noise at higherspeeds, but it couldn't be anywhere near as bad as stock.
Ultimate CPU Cooling Solutions! USA There's little to be said other than thats its a thermalright and you know it will perform well. Only thing to take into consideration is that you need additional fan and they tend to be more expensive.
Ultimate CPU Cooling Solutions! USA Another excellent cooler from thermalright if you can find it cheap or cheaper than the T-RAD it might be a more economical choice between the 2 and not to worry it still performs just as well.
I am sure I have missed many other offerings out, but I hope it has shown you there is a lot to choose from and at many different price points. Always do a little price checking to get the best deal
Canadian Prices: Search. Compare. Buy. - Canadian Online Shopping Search and Comparison! Quote:
Originally Posted by cgbc I have a PNY 8800gt with a crap cooler on it as well. I let it idle at ~ 60C with the fan at 30% because I can't stand the sound of it.
Anyway I've been looking at the Accelero S1 and according to reviews the drops with only 1x 120mm fan are already huge. Idle temps down to the mid 30s or so and load temps in the low 50s, if I remember correctly. That's pretty close anyway and with 2x 120mm fans you could probably drive load temps down into the 30s, with cool enough ambient temps.
I'm a bit frustrated that with the 1.1v BIOS mod I can still only get to 720/1782/1000 and I'm hoping that the Accelero can help me break at least 730/1850.
edit: OCed to 720/1782/1000 and case temps of around 40C, ambient ~ 25C or so, 1/2 an hour of Furmark 1920x1200 8xMSAA got my card up to 74C, fan 100%. |
I don't know what you're complaing about 720/1782/1000 are impressive clocks and quite honestly an additional 10Mhz is going to show little to nothing in improvements other than killing your 8800GT a little faster. If you want even more performance you'll have to voltmod your card to increase the amount of voltage to the core.
If you're interested please read:
8800GT Volt-Mod - Guru3D.com Forums
