Old October 25, 2008, 02:30 AM
S_G's Avatar
S_G S_G is offline
Default Single-slot coolers
So, just wondering, are there any good single-socket coolers available? The only one I know of is fullcover water blocks, definitely haven't heard of anything air cooled.
I'm looking to swap the coolers on my GPUs, but (= PCIe, - PCI, / RAM)
Code:
|    ////// (need all 4, RAM)
|========   (need this, GPU)
|-------    (need this, audio)
Code:
(= PCIe, \ cooler)
So, I can't use anything that runs backwards,
as it would get in the way of my RAM:
I can't use anything that would take up two slots,
as it would get in the way of my sound card:
Are fullcovers my only choice? Is there no other single-slot heatsink other than the crap ATI uses?
Edit:
http://www.hardwarecanucks.com/forum...er-review.html
Does the GFXChilla 4 obstruct the next slot if I run it fanless?
HTPC: MSI Z77A-G43 + i5-3570k@4.6 + 16GB DDR3-1600 + GTX 580 + X-Fi Platinum on water
Work: 13" MacBook Pro Retina 512GB
Old Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro
Old October 25, 2008, 03:15 AM
1Tanker's Avatar
I think you'll find you're SOL. Do the stock HS/Fs keep the cards cool enough for you, when turned up in Rivatuner? If so and you're just tired of turning them up in R/T..you could always unplug the stock fans, splice them together, and run them through a fan-controller(if 100% is too loud). GL in your search.
