  #21 (permalink)
Old October 27, 2008, 09:37 AM
Yep. So the question remains...will ASUS use the same pcb, or use 4870x2 pcb...? From the pics, seems like they have chosen to limit clocks by limiting power.
  #22 (permalink)
Old October 27, 2008, 09:50 AM
TechConnect Magazine - Sapphire Radeon HD 4850 X2 pictured
2gb ddr3 though, nice for those with hi-res displays.
  #23 (permalink)
Old October 27, 2008, 09:52 AM
Tech Connect has my link as source. I suppose not everyone can read chinese though.
  #24 (permalink)
Old October 27, 2008, 10:01 AM
cwestwell's Avatar
Yeah the 4870X2 wasn't the biggest seller ....it's taken the premium spot so it came with the most premium price $619 - $720 which is why I think the 4850X2 would offer a sub premium card in the same price range as the 280 with better performance which would equal more sales for ATI.
That Chinese site (often shifty but sometimes correct) If I didnt now better I would say that is a Saphire 4850X2 or more likely An ASUS ROG Xtreme 4870X2 it looks similar to the ROG 3870X2 but time will tell...and as Skymtl said it will be limited in release .....Only time will tell I guess
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
  #25 (permalink)
Old October 27, 2008, 10:35 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Personally, I think that due to the limited release you will be better served with buying a GTX 280. ESPECIALLY considering the associated problems that come with running a dual GPU card.
  #26 (permalink)
Old October 27, 2008, 10:50 AM
If these cards are sideport enabled, then they are worth it, IMHO, but if not(and from the looks of the pcb, they are not), it's a waste of shelf space, IMHO. single-gpus only.
  #27 (permalink)
Old October 27, 2008, 11:43 AM
SKYMTL's Avatar
Considering ATI has not enabled the Sideport feature on their own cards, I highly doubt that the likes of Sapphire, Palit and ASUS will enable it. But, you never know.
  #28 (permalink)
Old October 27, 2008, 12:01 PM
the reference PCB's have it, but it's not driver enabled, AFAIK.
  #29 (permalink)
Old October 27, 2008, 12:16 PM
SKYMTL's Avatar
The reference R700 cards have the sideport feature but as I said, it is not enabled. This suits me just fine since at this point I just can't see applications needing the extra bandwidth afforded by the Sideport. What is really holding back PC games these days seems to be the bad coding that goes hand in hand with being developed in parallel with the console versions.
IMO, the Sideport's addition was more of a proof of concept rather than something ATI would have enabled right off the bat.
  #30 (permalink)
Old October 27, 2008, 12:22 PM
QuadFire really requires it IMHO. I didn't have very long with two cards before my first died, but I was still seeing the dreaded "microstutter" in specific situations. I do think that the sideport could lessen that, but as you have said, it's kinda up to programmers to make use of it first....and yes, proof of concept, like tesselation engine in R600, but that doesn't mean it cannot be used...
And really, the real use of sideport is under NDA, but I'm pretty sure a couple of the smarter guys out there can figure it out...
