If you are converting a DVI signal to an HDMI cable, you will not get sound. DVI bandwidth only supports your video signal, you will still need your audio connected through the soundcard.
Hey KnSKranky, that was the case a long time a go but now most cards allow sound out over DVI to HDMI. Most Nividia cards have SPDIF headers for you sound card to hook up to and ATI goes futher by integrating a audio codec in to thr GPU so you don't even need a sound card.
