Old October 19, 2008, 02:46 PM
Default Max upgrade for a Mac Quicksilver 500mhz?
Hey,
I have built an old G4 workstation up, and right now I have a 128MB video card in it, and I can't find what the capacity is for this computer. Does anyone know if it can handle a 256 or 512 card? If so, any suggestions of what to get or where to find them?
Thanks in advance.
Old October 19, 2008, 03:57 PM
JD JD is online now
Should be able to run any memory size video card, just find out what slot it uses (AGP or PCI). Though I have no idea about those Macs and I'm going to take a guess and say you are probably extremely limited to what you can put in it.
And it's definitely not 500GHz. No computer is that fast
Old October 20, 2008, 06:29 AM
MacJunky's Avatar
There was no 500Mhz QuickSilver(QS), The QS line was 733, 800, 2x800, 867, 933, 2x1000 and had a system bus speed of 133Mhz. If your CPU is 500Mhz then it is running on a 100Mhz bus so that would make it either a Sawtooth or Gigabit Ethernet(GBE) model.
The Digital Audio(DA) also had a 133Mhz bus and it's stock CPUs were 466Mhz, 533Mhz, 2x533Mhz, 667Mhz and 733Mhz.
If you are running a QS or DA with a CPU from a Sawtooth or GBE then it will automatically run with the bus speed at 100Mhz so you do not have to manually push the multi down.
Before I can better answer your question though I really need to know what motherboard you have.
I can say this however:
Sawtooth - 2x AGP
Gigabit Ethernet - 2x AGP
Digital Audio - 4x AGP
QuickSilver - 4x AGP
The 2x AGP models max out at Radeon 9800, GF6200 and GF5200
The 4x AGP models max out at GF7800GS*, GF6800, GF6600, Radeon 800/850, FireGL x3.
* You need a card with a G70 core because the G71 core is too different and requires a different ROM(G71 is essentially a GF7900 sold as 7800)
The Mac Elite: Compatibility <- read this.
The reason you cannot toss any old card in is because Macs that use PowerPC CPU do not use the same BIOS as PCs, they use OpenFirmware(google it for more info). To make a gfx card from a PC work in a PPC Mac (or even an x86 Mac (They use EFI)) you need to flash an OpenFirmware compatible rom/bios to it(we Mac users call em ROMs instead of BIOSes). Thankfully Apple shipped some of these cards in Macs so most of the time you can just flash a different one to the card. Some PC cards have a smaller EEPROM than the Mac variants(32kb vs 64kb), so in those cases you either need a reduced ROM or you need to solder a bigger EEPROM onto the card.
As for CPU the max you are going to go with Sawtooth/GBE/DA/QS is single 2.0Ghz PPC 7448 or dual 1.8Ghz PPC 7447/7448
All the G4 towers listed above can take 3.3v 168pin 512MB SDRAM modules. I do not have the specifics on the RAM off the top of my head but just toss some old RAM from a previous PC build in and see if it works.
Now, as for better identing your computer if you are running Mac OS X go to the apple menu at the top left of the screen, click it and select "About this Mac" then in the window that pops up click the "More Info" button. Apple System Profiler should open and list the specifics of your hardware.
If you are running Mac OS 9 then just select "Apple System Profiler" from the apple menu.
If it has no operating system we can ident it via motherboard as well if you would like. I have most of the model specific differences for the first 5 G4 motherboards memorized. :P
Old October 23, 2008, 03:03 PM
MacJunky's Avatar
Thread Killer(me) strikes again?
Anyone have anything else helpful to say? Am I _really_ the only person here who knows anything about Apple's G4 towers?
So Granger24, do we get to know what you are going to do with your G4? Do we at least get a picture of it's innards?
Old October 23, 2008, 03:08 PM
sswilson's Avatar
Heh....
I missed your last post and am pretty well sitting here with my mouth agape at the full range of info you were able to provide. :)
