Old October 18, 2008, 09:05 AM
Skyllz's Avatar
There you go... barely fits
Is smoke supposed to come out of there?
Old October 18, 2008, 09:21 AM
CTA's Avatar
CTA CTA is offline
Originally Posted by Skyllz View Post
With my Q6600 @ 3.2ghz I pulled a 17500 in 3dmark06, i'm happy!!
from what number?
i admit this is little unbelievable... o_o
and glad to hear that you like it...
ps. you need good airfolw for your gx2 because i see that hdd cage block that way.
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old October 18, 2008, 09:54 AM
Skyllz's Avatar
My Sonata case has not seen his side cover in months... ;) This is why i'm getting a NineHundred, I'm picking it up monday night.
I'm surprised that after bumping my Q6600 to 3.4 and OC a little the 9800GX2 i'm not seeing better results then at 3.2/stock clocks... weird.
This is at 3.4/OC'ed 9800GX2.
Old October 18, 2008, 11:09 AM
"Quote This..."
I'm not surprised. I recently downclocked my q6600 from 3690 back to 3200. I did so because the fps difference was like 1-4 slower and I was able to drop the vcore from 1.525 to 1.25, easier on my passively cooled system.
World in Conflict actually got faster, dunno why but I retested it just to be sure it was not a fluke and yes, 5-6 fps quicker on the slower clock. Go figure.
Old October 18, 2008, 11:53 AM
Skyllz's Avatar
Seems to be a fine line between running more ghz, hotter and less but cooler as far as end of line performance goes.
Old October 18, 2008, 05:49 PM
CTA's Avatar
CTA CTA is offline
odd...my evga gx2 has average 62C unlike your xfx gx2...
anyway impressive...
maybe because of memory? i mean you have to explain why? >.<
Old October 18, 2008, 09:23 PM
Skyllz's Avatar
I did crank the fans to 100% while I benhed it with Rivatuner, that might help.
Normal temps are around 60 otherwise.
Old October 19, 2008, 01:06 AM
Ah, that makes sense, yours is a different style of sonata, mines a sonata plus 550.
The hard drive bays are set in the traditional way on this case, and the cage is just that little bit in the way. Nothing a die grinder cant fix though.
As you see here, the GX2 is about a centimeter too long.
About the Q6600, I also found that gaming was slower when i ran it past about 3.4 I never bothered to quantify it by checking framerates, and 3dmark always registered higher marks with it faster, but real world gaming "felt" slower, and the computer not quite as responsive.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
