Old October 16, 2008, 02:42 PM
Default Sapphire 4870 Open Gl issue
I want to play Medal of Honour Breakthrough
but once I start it up, the console loads at goes into game window, then it crashes
I can't find a soloution anywhere.
System Specs
Op's Vista 64bit SP1
Ram 4GB 1062 mhz Corsair Extreme
GPU Sapphire 4870 Catalyst ver. 8.10
I've tried re-installing the game and Catalyst
Can anyone help me?
__________________________________________________ ________________
SOLOUTION!!!!!
Please note the following is what i found. It worked for me and i was able to load multiplayer etc, I just tryed it for a few minutes I don't know if the game will crash at any point etc. But it's better then what Ati's offering.
Requirments
A little Tech know how
You will need to know how to use command line etc.
Search Engine, how to get around you hard drive.
Working on download
You can go through the following steps for yourself or download the file from this link
~~~~ PLEASE NOTE DOING EITHER IS AT YOUR OWN RISK!!! ~~~~~
This is my own website from many years ago so i mean it's going look pritty shady deal but whatever
If you feel it's to big risk just go through steps below
" The driver's reported OpenGL string is too long for the program's buffer to hold, hence overwriting stack memory and causing the crash.
nVidia implements application detection to work around the problem by clipping the OpenGL extension string, and I suspect ATi may have to do the same to fix the issue.
Steps to follow:
1] Download 8.6 drivers.
EDIT: Double click the ccc icon and it will copy all files to ati/support.
DON'T install. Click cancel when the installer appears. You will
only need 2 files from this older CCC. The rest is for the bin.
2] Go to the support map and navigate to atioglxx.dl_ and atioglx2.dl_.
** Edit From Ghost **
I could only personally find " atioglxx.dl_ " file and it worked for me
Go to C: Driver
then "ATI"
then "SUPPORT"
Select version 8.6 or what everone you you want for all i care (I don't know if it works for anyone)
For Xp users Use search engine on the Version 8.6 ..... type something close to atioglxx.dl_
For Vista open the version folder and use search engine
Vista Users Warning
For the following steps they did not work for me on Vista so I hooked up my Windows Xp Home and did the Operation on there.
3] Take out atioglxx.dl_ and atioglx2.dl_ and put them on c:\
Putting them on c:\ makes it easier to find/acces them in the next step.
4] Open a command prompt and type:
CD\
hit enter then type
expand c:\atioglxx.dl_ c:\atioglxx.dll
expand c:\atioglx2.dl_ c:\atioglx2.dll
Watch the spaces !
This will expand the files into dll's.
U will now see 2 files identical to the ones you placed there earlier, except that these new files are now recognized as dll's.
If you get a "can't read out put file"
type
attrib
If the atioglxx.dl_ has any letters written be side it go back to the files location right click and change security restrictions to full authority.
5] Next put these two files into your MOHAA map. This is the map where your exe is. DO NOT put it in mainta.(or anywhere else for that matter...)
Only the games in this mohaa map will use these new opengl dll's. This includes mohaa, mohaas and mohbt. Your other games will use dll's from cat 8.9., or whichever version u have installed.
6] Start the game. Voila.
*U can remove the 8.6 driver map cos u already got what u need out of that map.
*If the 8.6 dll's dont work, then try other versions and retry steps.
*I got two HD4870 so any1 with that card should follow this to the letter."
By Roscoe on AMD Forums
Link to Post
AMD Game Forums - Is 48X0 going to be compatible with MohAA?
Old October 16, 2008, 03:47 PM
hausner's Avatar
Try older drivers maybe there is solution.
i7 6700K / Asus Z10L Pro Gaming/ Asus 1070 /Corsairs 16GB DDR4/ Samsung Pro SSDs/Enthoo Evolv mATX
Old October 16, 2008, 05:06 PM
CanadaRox's Avatar
I'd try the 8.7 version of the CCC as it seems like a there is an alarmingly large number of people having problems with the newer ones. And when you change drivers (or reinstall your current ones) make sure you uninstall, use a driver sweeper, then reboot and install.
Project: Black and White
Old October 16, 2008, 08:24 PM
arekieh's Avatar
CS 1.6 (Open GL) runs fine with me with my Powercolor 4870. Im using Beta Cat .10's
Mobo: Asus P6T Deluxe | CPU: i7 940 | Ram: 3x2 GB | HSF: CM V8 | GPU: HD 6950 | PSU: PCP&C 750W | ]HDD: WD 500gb x3, 120GB Vertex 2 | Case: Antec 1200 | Monitor: 3x Asus VE247H | OS: Win7 Ultimate x64
My Trading Rep:
HWC
OCN
Heat
Ebay
Old October 17, 2008, 09:10 AM
I'll see what happens once I install an older version,
Thanks for you time
Old October 17, 2008, 11:45 AM
Well still no luck on older versions
Old October 17, 2008, 12:13 PM
Dr_BenD_over's Avatar
Fallen Folder
Was the game originally installed with the 4870 present? Or did you install it originally with a different card? There might be some sort of ini in your my Documents folder that doesn't get deleted when you uninstall the game. I know BF2 could be a real pain because of that.
All's well that's Haswell
Old October 20, 2008, 09:50 AM
It was a whole new build from the ground, up
Old October 20, 2008, 01:34 PM
belgolas's Avatar
Yeah that has happened to me before with BF2. Grr.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old October 22, 2008, 09:14 PM
SOLOUTION!!!!!
Requirments
Working on download
Steps to follow:
Go to C: Driver
then "ATI"
then "SUPPORT"
Vista Users Warning
CD\
hit enter then type
Watch the spaces !
type
attrib
Link to Post
