Old October 12, 2008, 08:19 PM
Dar_ell's Avatar
Ooo BIA hells Highway? How is it, i might pick it up when im not busy. back to the topic, i also noticed my temps were maybe 5-6C higher.
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old October 12, 2008, 08:55 PM
Infiniti's Avatar
I don't like BIA Hell's Highway for some reason..
Also, 8.9 works fine for me too, but I use Rivatuner to change my fan speed.
Old October 12, 2008, 11:43 PM
cwestwell's Avatar
well all is fixed...thanks all
I have just been lucky for a long time not having issues........I guess I was bound to do a driver cleanup sooner or later.....back to gaming...phew
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
Old October 14, 2008, 03:17 PM
arekieh's Avatar
Ill tell you in 15 minutes if mine is acting up. Just got my Powercolor 4870 :D, installing 8.9 Cat's right now.
Mobo: Asus P6T Deluxe | CPU: i7 940 | Ram: 3x2 GB | HSF: CM V8 | GPU: HD 6950 | PSU: PCP&C 750W | ]HDD: WD 500gb x3, 120GB Vertex 2 | Case: Antec 1200 | Monitor: 3x Asus VE247H | OS: Win7 Ultimate x64
My Trading Rep:
HWC
OCN
Heat
Ebay
Old October 14, 2008, 09:12 PM
Killswitch's Avatar
I was starting to have some major issues with games causing artifacts and crashing to the desktop........ mostly Crysis Warhead . I thought it was the 8.9 drivers but other games where fine, and Crysis used to be too. Turns out it's the cards powerplay feature changing the gpu speeds during the game and causing things to go for a shit. So, what I did was create two profiles with overdrive checked off in the settings list. I named one for stock/desktop and the other for gaming. I then opened the GAMING.XML file in notepad. For Vista users this file is located in C:\Users\%yournamehear%\AppData\Local\ATI\ACE\Prof iles. Oh and you'll have to show hidden files and folders to find it too BTW. Anyhow, this is what I changed in the .xml file........
Feature name="CoreClockTarget_0"
Property name="Want_0" value="50000" /
Property name="Want_1" value="50000" /
Property name="Want_2" value="84000" /
to............
Property name="Want_0" value="84000" /
Property name="Want_1" value="84000" /
If you have a stock bios the number 84000 will/should say 75000, or whatever your stock 3D gpu clock is.
While I was at it I also changed the following which sets the fan at 50% speed for the GAMING profile........
Feature name="FanSpeedAlgorithm_0"
Property name="FanSpeedAlgorithm" value="Automatic" /
Feature name="FanSpeedPercentTarget_0"
Property name="Want" value="0" /
to
Property name="FanSpeedAlgorithm" value="Manual" /
Property name="Want" value="50" /
The STOCK profile is made so you can set everything back after you exit a game. I found these tweaks elsewhere on the net and I can't remember exactly where but HATS OFF to the first guy who figured this stuff out!!!!! It's easy to do and it cleared up ALL of the little issues I've had with card so far. *knocks on wood*
Old October 14, 2008, 09:47 PM
arekieh's Avatar
sorry for not replying as quick as i said i would, i had major problems with cat 8.9. I didnt even try fixing them though, i jumped straight to Cat 10.1, they are awesome, manual fan speed FTW :D
My Trading Rep:
HWC
OCN
Heat
Ebay
