Old September 30, 2008, 09:05 AM
Default Geforce + Quadro
Hey all
can 8800 series (more specifically 8800 GTS) be used with a quadro (not in SLI)?
i have two screens and I will like to drive the secondary with the 8800 provided their drivers won't conflict with each other.
thanks!
Antec ninehundred
Intel Q6600 B3 stepping
OCZ Platinum Rev.2 DDR2-800 1G X 2
BFG 8800GTS OC2 640MB
Seasonic S12 650W
Old September 30, 2008, 10:20 AM
Spaceman-Spiff's Avatar
I'm guessing the driver will conflict. It'll be nice if they can work together, if you can switch around the "active" video card. I have a friend who is a Quadro user who is an avid gamer too. He has to switch to his other PC just to play games.
There's a post about it on nvidia forum: NVIDIA Forums -> Running Quadro and GeForce Card on Same Machine. No replies, and pretty long instructions. And the guy who did it said: "If everything is configured correctly, the system runs quiet fine. When you make some mistake as I did, you may need a month to fix it ".
Old September 30, 2008, 08:24 PM
thanks that points me to a good direction!!
i will take a look at the posting and see if I can get mine to perform!
Antec ninehundred
Seasonic S12 650W
