Old September 18, 2008, 05:55 PM
Default Help, Need some advice on a upgrade from a GTX260
So my EVGA GTX260 (192) SP just showed up yesterday. Now before I open it I am thinking about the possibility of selling it unopened for 300 Cash here in Canada then buying something better.
I see on EVGA's website they are selling the
EVGA GTX260 (192) Core for 299.99 USD
http://www.evga.com/products/moreInf...eries%20Family
And the
EVGA GTX260 (216) Core for 299.99 USD
So first off I see that for the same price I could get the new 216 Core GTX260
But here is a bit of a catch for trying to step-up, I just had a EVGA 9800GTX which I used to step up to the GTX260 basically for free. I bought the 9800GTX four months ago when it was just over 300 bucks USD, Then as the Price of the GTX260 dropped, I cashed in my Step-up to get the GTX260 for free
So stepping up again is out of the question says EVGA.
I could sell my unopened GTX260 then buy the core (216) GTX260 for 299.99, But does anybody have a better Idea to get more performance for my 300 dollar Canadian?
Is there any ATI products that would beat my GTX260 (192) core for around 300 Bucks?
Really need some solid advice people to get the most gaming performance I can for my money
Thanx
System spec: Intel i7 2600k, Gigabyte GTX 570 Super Overclock, Kingston DDR3 2X4 GB sticks, ASUS P8P67 PRO, Cooler Master 700 watt PSU, 750GB*2 Sata,SATA III 1TB HDD Acer 24 Widescreen, Antec 300, Windows 7 Ultimate 64 Bit
Old September 18, 2008, 07:26 PM
JD JD is online now
IMO you aren't going to get $300 for your card since you can get it new for $260 after MIR, plus a full warranty since I don't think EVGA's warranty is transferable, but I could be mistaken.
The HD4870 is spot on with the GTX260 (192) I believe though the 216 was released to plainly beat the HD4870.
However, the GTX260 will suit you fine regardless of 192 or 216SP. It's a solid card.
Old September 18, 2008, 09:29 PM
cwestwell's Avatar
Yeah holding onto the 260 192 is no sin its a solid card the Core 216 makes pathetic gains over it. Nvidia only released it to defend the spot against the 4870 however the 4870 continues to drop in price and still outperforms the 260 in higher res AA FPS. All in all open the box and give it a spin you wont regret it......however hmmm the 260 216 is quieter...well scatch that I dont know......return it pay the restocking fee and get the 4870 (jk)
_______________________________________________
E8600 420x10 |Thermalright 120 Black | Maximus Formula | ATI 4870X2 | 4GB Buffalo FireStiX PC8500 | Corsair HX1000 | Lian Li V2010B | Vista Ultimate 64bit
Q6600 334x9 |Thermaltake Blu Orb | ASUS P5Q-PRO| ATI 2900XT | 6GB Corsair XMS2 PC6400 | Corsair HX520 | Lian Li V600B | Vista Home Premium 64bit
Old September 19, 2008, 09:40 AM
rjbarker's Avatar
I'm in exactly the same boat, only I purchased the FTW edition ($329 after MIR) and of course one week after purchasing...boom...new 216 Core! However, the Card is amazing, not just the speed (130 GB/Sec Bandwidth OC"d to 720/1475.2.4Ghz), but the Load Temps. Under Load playing Crysis it barely breaks 60 celcius, my old 880GTX was close to 80 celcius!
As mentioned, you could simply retrun it,(I cannot as I've "cut-out" the Bar Code for MIR) or just go with it until the new 55nm's appear!
"Just enjoy it"
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old September 24, 2008, 04:24 PM
rjbarker's Avatar
Update: DC is taking back my GTX 260 FTW (even minus the Bar Code)...way to go DC, thianks for all your help on this one Corey!! Now, I will be recieving a new GTX 280 SSC to compliment my Samsung 24"!!
Timespy: 18.613K
MARK 11: 40.185K
Old September 24, 2008, 04:37 PM
magictorch's Avatar
That was good of them, the GTX280 is hell of a card.
Old September 24, 2008, 04:59 PM
cwestwell's Avatar
Wow that is impressive ...even with the UPC code gone...I guess we can look forward to large open box sales from DC and NCIX I am guessing they are having these kinda requests often
Old September 24, 2008, 06:01 PM
Dadi_oh's Avatar
I would just keep the GTX260 192. Jumping through that many hoops for 24 shaders is not worth it IMHO. Plus the GTX260 overclocks like crazy. I have mine at 756/1512/2500 without even bumping the voltage in the BIOS (I am at 1.06V). At those clocks you are in GTX280 territory for anything but the highest resolutions.
Mine benches Crysis 41.3 fps at 1680X1050 4XAA for reference.
Rig1: Q9550 @3.8GHz Vendetta 2, P5Q-PRO, 6GB OCZ Reaper PC2-8500. 5870 1GB, GT240 Physx, Ultra LSP 750W, 2TB internal + 2TB external, 3X23" 5760X1080 eyefinity + GT240 Physx, HAF22 case 3X200mm : Win7 Pro
Rig2: E8200 @3.6GHz Vendetta HSF, DFI P45 LP-JR, 4GB 900MHz, 4870 512MB, X203W 20", Ultra Gladiator Case
Rig3: Q6600@ 3.5GHz H50, P5Q-PRO, 8GB, 8800GTS512, OCZ GameXStream 850W, Samsung 245BW 24" + 19" dual: Snow Leopard + Parallels Win7
Rig4: MAC mini Snow Leopard
Laptop: Macbook Pro 15"
Old September 24, 2008, 07:35 PM
Eagle Eye's Avatar
Is the GTX260 a worth while upgrade from my 2 8800GT's with my current system specs or would I be highly limited by my cpu? Prices keep falling on these and I gotta stop the itch sooner or later.
Would a GTX 280 simply be overkill for my system?
I bet someone over at DC staff just bought yours, given the circumstances I would let you return it without the UPC code you're buying something thats much more expensive.
EE
Old September 24, 2008, 08:01 PM
Dadi_oh's Avatar
EE
If you are already running 2 X 8800GT in SLI you are about equivalent to GTX260 speeds. Since you have already invested in the SLI setup (mobo, power supply) I would not bother. What resolution are you gaming at? That would factor in as well.
