It sounds like an interesting concept, the only issue is that with a CPU bottleneck there really is no clear cut and defined line as to where it starts and/or ends. Everyone's interpretation of a bottleneck is going to be different. Frames are going to increase at a rather rapid pace initially, slowing down as the CPU gets faster, however there will always be an incline. The best way to show this would be via a curved graph showing the steady progress as the CPU gets faster and allow readers to determine what they would consider a bottleneck. That however, it really doesn't guarantee any answers, it merely lays out information that could have been approximated. I'm going to ponder over this and see if there would be a way for it to be useful while still remaining clear and informative - Not requiring people to think or guesstimate the results, but actually show tangible numbers. |
With the review timeline, adding this to the GPU reviews is impossible. Forget about us wading into the PCI-E 2.0 / 1.1 bottleneck fiasco as well. That is set in stone. Maybe in a seperate article we will look at CPU bottlenecking but I would have to look at the viabiliy of testing methodologies. If they do not produce repeatable results Hardware Canucks will NOT broach the subject. |
I could volunteer my system as a PCIe 1.0 benchmark system and underclock my cpu slower and slower to give a comparison? Not that Im trying to be greedy or anything, but just if it's a necessity. I think the good people of the forum should know whether or not their first gen PCie-based system (of which probably 50-60% or more of the forum has) can take advantage of a new video card or if a "lesser" newer card would offer the same performance without being as expensive. Either way... I'll help if i can (Im buying the 4870x2 when it comes out either way, lol).
__________________ Current System: "Gale Force" (09-28-2008) AMD X2 6000+ w/ TRUE (2x Scythe 120mm) | Asus Crosshair MB | 4Gb OCZ Plat.Rev.2 PC-6400 RAM w/ Corsair Memory Cooler | VisionTek 4870X2 2gig| Coolermaster CM Stacker 832 w/ 7x 120mm Fans (2x Tricool, 5x CM), 1x 80mm CM, and 1x Antec "Big Boy" 200mm Tricool Fan | Silverstone Strider 1Kw PSU | Seagate Barracuda 7200.11 500gig x 4 (Raid 1 & Raid 0)| 3x BenQ FP222w 22' Wide 5ms LCD Monitor & Matrox Triplhead2Go DE Next system? Who knows... |
| Quote:
Imagine the amount of hardware a reviewer would need to keep on hand in order to satisfy all of the different questions folks would start to expect answered... Where would a person draw the line? C2D vrs AMD? PCIe 1.0a vrs PCIe 2.0? DDR2 vrs DDR3? 8X vrs 16X? The list goes on and on, and even if one person had all of that hardware available, the time constraints on doing a normal review/benchmark would be quadrupled. Keep in mind that a standard review of even the simplest item takes 30+ hours to put together.
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
I think with a test of different cpu speeds with 4870X2 in PCIE1.0 or 2.0 you would need to control for confounding variables like differences among chipsets or the bios. That in itself will make a really accurate comparison very difficult. The best case scenario is simply to test a range of PCIE 1 boards vs PCIE 2 boards at different cpu speeds and see where the results take you. Thats a lot of work though.
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. Last edited by magictorch; July 24, 2008 at 08:34 PM. |
I agree it's alot of work, but it answers questions that lots of people ask. The most important of which is "when is the right time to upgrade?" or "what do i buy for my system?" etc etc. It was just an idea tho.... If it ges voted down I'll stay silent and just tell you guys my FPS in games when i get my 4870x2.
| Quote:
Your right, the consumer needs to know where they fit into the big picture. After all without the consumer where would these companies be? These are not cheap toys we buy. The ever growing number of chipsets or GPUs and their partners plus the cpus and bios support make for confusing times for those looking to work out when or how to build a strong gaming rig. Add to the mix the game developers and you have a mess at the cutting edge. Makes you feel more like a testtube in an experiment with 30 variables and no degrees of freedom. Its about time things became more objective for the cutting edge perhaps in terms of reviews. This site is definitely a step in the right direction.
__________________ E6750 + Apogee GT block DFI X38 LT 2x4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black) Loop 1: MCR 220 int. + cpu Loop 2: MCR 320, Swiftech Res. + 2x EK FC blocks) Pumps: 2x MCP655. |
| Quote:
Whether or not it gets done now, slated for the future or not done at all, we ALWAYS need idea for content. If we aren't able to show the way products get bottlenecked, maybe this idea will spawn a spin off that is a huge hit, but the only way to get that is through feedback and suggestions like yours. People are going to "pick apart" or change the original idea and it morphs into something awesome. Don't be discouraged, keep those ideas coming |
Maybe it would be possible to run just a few of the tests on bottlenecked hardware? Take a few of the tests with the lowest score and test them with slower CPU(maybe 1 or 2 of the slowest results), just to get an idea of where the bottleneck affects our realworld performance. Other than that the only thing that could possibly work is running the reviews on a machine that resembles one you would find in the house of one of the forums members. I was so happy when you did that review with the Q6600, has a lot more relevance to me than a review based around a machine that makes mine look like a kids toy.
__________________ "...you play a mean banjo" My system: Haven CPU: Core 2 Quad Q6600 @ 3.0Ghz | RAM: OCZ Platinum Rev.2 2x2Gb | Mobo: Asus P5KC | GPU: MSI 8800 Ultra | Case: Silverstone TJ09 Cooling: D-Tek FuZion v1 | Swiftech MCP655 | MCR120 | MCR220 | PA120.3 | EK-FC 8800 Ultra |
| Thread Tools | |
| Display Modes | |
