Go Back   Hardware Canucks > HARDWARE CANUCKS NEWS > Suggestions & Feedback
View Poll Results: Would you like to see F@h numbers in every CPU review?
I would like F@h to be included as benchmark in CPU reviews 19 95.00%
I would not like F@h to be included as benchmark in CPU reviews 1 5.00%
Voters: 20. You may not vote on this poll
Old January 23, 2013, 10:45 PM
Dead Things's Avatar
Maybe DT or 10e know more about the V7.
Tim_H is our neighbourhood V7 guru. I'll ask him to check out this thread.
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Old January 24, 2013, 06:37 AM
Tim_H's Avatar
Hey,
So I've never tried to capture a wu in V7. I'll look into it and see if there is a way.
I know that there are "features" that detect whether or not a wu is old and it will automatically return it (there should be an option to ignore it)
all of the data is kept in a weird place. it's C:\Users\%username%\AppData\Roaming\FAHClient
in there you will find the cores, config file, work folder and some other stuff as well. inside the work folder you will find (if you have a slot running) a folder numbered to match what is shown in the "Work Queue" section of FAHControl. There shouldn't be a problem to copy/backup those folders and then overwrite them when you want to test a specific wu.
The trick is going to be keeping it for later when the deadline has past. That I'll have to look into
Old January 24, 2013, 06:42 AM
great_big_abyss's Avatar
I could imagine there would be a problem with the bonus calculation if the deadline is past.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old January 24, 2013, 07:21 AM
Tim_H's Avatar
It would be a problem for monitoring programs, but if you use the calculator that Charlie linked using the tpf it wouldn't be a problem.
Folding Forum ? View topic - Guide For Running bigadv On Windows Natively (A3 Core)
This set of instructions was written using the V6 Client, which has been a while since I used it. For a GPU Client, the 'SMP2' folder should be named 'GPU'. The 'Work' folder remains the same. For consistency, I would let the WU be folded for 10 frames, since the tpf (time-per-frame) can vary ever so slightly. Once you have an average tpf, this site could be used to calculate an average ppd (points per day): Folding@home Bonus Point Calculator
Old January 24, 2013, 07:34 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Exactly.
HOWEVER, if there is a way to keep the WU and reset it to zero completion, it should be relatively easy to use a TPF -> PPD calculator to determine points value...I think.
The only thing is how would you reset the WU and load it into a new system?
Old January 24, 2013, 07:53 AM
Tim_H's Avatar
I'd just copy it to another location when it was new. the only problem would be the deadlines I think.
I know with version 6.34 there were options to:
1. ignore deadlines
and
2. ask before sending/receiving data (or something along those lines)
Old January 24, 2013, 08:32 AM
Tim_H's Avatar
I found the option for ignoring the deadlines. I'll see what I can do about actually capturing a wu and getting it to run a second time.
I'll let you know how it goes
Old January 29, 2013, 06:37 AM
Any luck in recycling a used WU?
  #19 (permalink)
Old January 29, 2013, 06:40 AM
SKYMTL's Avatar
Yeah, I would like to know as well.
  #20 (permalink)
Old February 13, 2013, 08:54 AM
Tim_H's Avatar
I did try a quick test(simple copy paste), it didn't like it.
I haven't had a lot of time to play with it yet. I plan to this week/weekend as I have some time free coming up
[WTB] WTB LGA775 CPUs micul Buy/Sell & Trade 14 June 4, 2011 11:21 AM
New AMD CPUs [Youtube] Jamula66 Rumor Mill 47 January 23, 2011 11:49 AM
AM2+/AM3 ITX Motherboard for X6 CPUs? tehpr0fess0r CPU's and Motherboards 0 May 20, 2010 04:09 PM
Reviewing DFI LANPARTY MI P55-T36 top efficiency Intel ITX platform windwithme Member Reviews 10 March 17, 2010 12:28 PM
ebay and the cpus omgwtf CPU's and Motherboards 20 January 20, 2008 04:23 PM
