-   Suggestions & Feedback (http://www.hardwarecanucks.com/forum/suggestions-feedback/)
-   -   Support Question (http://www.hardwarecanucks.com/forum/suggestions-feedback/54995-support-question.html)
satchmo2002 June 23, 2012 10:25 AM
Support Question
I do not say any support related field so I will post here.
For some reason all of the sudden the forums are saying that I do not have permission to post in the "LinusTechTips Q&A" forum.
What's going on? Thanks.
sswilson June 23, 2012 12:15 PM
You can't post, or you can't create a thread?
If the problem is that you can't create a thread, you aren't supposed to be able to (http://www.hardwarecanucks.com/forum...ew-thread.html) if you can't post, please link to the thread you're attempting to post into and I'll attempt to post myself to see if it's a global problem.
satchmo2002 June 23, 2012 04:24 PM
Ok, thanks. I didn't see that change had been made since I last posted, ty for help.
