I think Gav should make the font for the thank section under each post a bit smaller.
And yea, remove the header and tack something small onto the end of the list of names.
liike:
User, MoarUser, Randomguy, Per'smom, Thank <poster> for this post.
Also, Enab, in the case of your info thingy, there is not really any wasted space when compared with before. It is mostly just us with our rig specs menus and/or small avatars.
http://poopr.org/images/s5bolzdydwpcsrtz0x1.png <- this is how I see the forum
(yes I did change my system fonts, Lucida Console ftw) (monospaced fonts are how one needs to roll!) (also, if you change your system fonts you notice that microsoft's sites use whatever font you are using :D )
