Go Back   Hardware Canucks > HARDWARE CANUCKS NEWS > Suggestions & Feedback
Old October 14, 2009, 05:41 PM
MpG's Avatar
MpG MpG is offline
Default Changing message editor width?
This may have been brought up before, but is there any possibility of having a user option to make the standard message editor wider, particularly for PM's?
I just finished putting together a reasonably length PM, and even after stretching the screen downwards by a factor of about 8, a scroll bar was still needed. It's also a little disconcerting to bounce up and down so much through the same paragraph. The posting and quick-post text boxes are fine, it's the PM ones that seem unnaturally compressed sideways.
Old October 14, 2009, 05:45 PM
FiXT's Avatar
Hall of Fame
Check the bottom right hand corner in the white space - Should be two small lines. Grab it with the mouse, drag and make bigger :D
Old October 14, 2009, 05:58 PM
MpG's Avatar
MpG MpG is offline
Alright, I'll bite. Am I missing something? Doesn't seem to be that option anywhere.
Old October 14, 2009, 06:09 PM
3.0charlie's Avatar
Just checked, and I can increase the size vertically (arrows next to the spell checker), but not horizontally.
Hydro-Quebec is salivating...
Old October 14, 2009, 06:10 PM
sswilson's Avatar
Heh... methinks FiXT has a few extra buttons at his disposal... I don't see it either. :)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
Old October 14, 2009, 06:13 PM
sswilson's Avatar
Good catch 3.0Charlie!I always assumed that was for increasing font/heading size.
FiXT's Avatar
Hall of Fame
Looks like a spoke a little to quickly. I just checked IE7 and FF and they don't have it. Appears to be Chrome browser available ONLY :P
That said, right up by the top, right up by the "Switch Editor Mode" and Spell Check" are a few up and down arrows, and you can use those on any browser to extend it vertically like 3.0 said.
Old October 14, 2009, 09:59 PM
bojangles's Avatar
Definitely not on Firefox that's for sure. Gav can we get a fix for this please?
Old October 14, 2009, 10:28 PM
MacJunky's Avatar
As of a couple years ago(I dunno about nowadays) the nightly WebKit builds had a resize text box ability.. 'course, that is for Macs only unless I am mistaken.. >_>
Old October 15, 2009, 09:34 AM
headsh0t's Avatar
omg look how far you can expand it vertically. It never ends!
Urgent Message Arinoth Off Topic 11 September 16, 2009 12:55 PM
Problems Burning DVD from Video Editor - Vista Problem? jgerber O/S's, Drivers & General Software 0 March 22, 2009 09:25 PM
help me with the message please BrianHanna Troubleshooting 3 February 3, 2009 08:05 PM
Gamespot Editor Fired MpG Rumor Mill 11 December 8, 2007 11:26 PM
Problem with pci-e link width Uplasenko Troubleshooting 9 April 9, 2007 05:42 PM
