Go Back   Hardware Canucks > HARDWARE CANUCKS NEWS > Suggestions & Feedback
Old November 28, 2008, 09:58 PM
3 of 7's Avatar
Originally Posted by Infiniti View Post
If people can't login from home, why don't you just delete your cookies once and when you log in, tick the box that says "Remember Me". It makes things a lot easier. In fact, I never knew of this problem until recently when CCleaner cleaned my cookies..
If you go into "options" in ccleaner and then click "cookies", it will allow you to specify what cookies to keep..
What I did was run ccleaner and then I signed into all the sites that I normaly go to and opened ccleaner again, it was pretty easy to see what cookies to keep then.
Old November 28, 2008, 10:15 PM
LCB001's Avatar
Folding Captain
Don't know if its related but the price compare links aren't working
Folding For Team 54196
Old November 28, 2008, 10:49 PM
Gav's Avatar
Gav Gav is offline
Administrator
Seems to be working for me. Can you check again?
Old November 28, 2008, 11:06 PM
3 of 7's Avatar
The price check links don't work for me when I click on the actual link to the stores...
Old November 28, 2008, 11:07 PM
LCB001's Avatar
Folding Captain
Yup its working now. Just after the log out it gave me a 505 error, whatever that is, but was working again when I tried 10mins ago...
Old November 29, 2008, 12:43 AM
Patriote's Avatar
Originally Posted by thenewguy001 View Post
I'm having problems getting the server to remember me. I'm asked for a log in every time even though I check the "remember me" box. Only started happening within the last couple of days
Same here!
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old November 29, 2008, 07:04 AM
3 of 7's Avatar
I figured out why I couldn't get to the companies from pricecheck, it's because Google Analytics was blocked in the host file I'm using from MVPS
Blocking Unwanted Parasites with a Hosts File
Old November 29, 2008, 02:40 PM
I've had the problem for few days, finally able to log in.
Thanks for fixing issue.
edit: Having issues again, it is becoming a PITA to clear cookies all the time and then log in.
  #19 (permalink)
Old November 30, 2008, 12:36 AM
hightest's Avatar
cleard cookies / dang it just happened agian i was posting under samsung 850 post and when i went 2 submit it said i was not loged in
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
  #20 (permalink)
Old November 30, 2008, 12:54 AM
joeperson's Avatar
More hijackage: It seems running google analytics scripts is a required step for the price matching to work correctly. If it's blocked for an reason the links won't load. Hosts file is one way to block it, NoScript is another.
Also anyone not using NoScript in firefox should go get it.
Q6600 3.0GHZ (9x333) stockV | ATI 5850 | OCZ Platinum 4GB PC2-6400 DDR2 5.4.4.15 1.9V | Silverstone Raven RV01 | Gigabyte EP45-DS3R
Corsair Professional HX750W | Windows 7 | Crossbow mounted Xigmatek HDT-S1283 | LG W2242TQ-BF 22" | Samsung 2253BW 22"
