-   -   Harddrive upgrade time (http://www.hardwarecanucks.com/forum/storage/9779-harddrive-upgrade-time.html)
Hillsdale September 1, 2008 01:46 PM
Currently I have a x2 Seagate Barracuda 500GB hard drives and i want to upgrade one of them to a faster/ newer hard drive to play my games from, so i have some questions.
1) What hard drive do you recommend
2) How would i get my games to ONLY PLAY from that hard drive
Thanks! :canadianwave:
Tazer-[X] September 1, 2008 04:32 PM
install your games ONLY on that hard drive;p
Iamcanadian7 September 1, 2008 05:04 PM
Only thing thats going to be faster is a Raptor/Velociraptor.
I would suggest the 300Gb Velociraptor since the Raptors are only 150gb and thats a little small for a games drive.
To get them to play from that drive, choose that drive from the game installation and make a shortcut to the game from your desktop.
JD September 1, 2008 05:12 PM
Why not stick both 500GB drives in RAID0 and get a Western Digital 640GB drive to keep all important data on?
Obviously use the RAID0 array for the OS and games.
Jack Rabbit September 2, 2008 03:49 AM
I would recommend waiting. Right now you will have so spend quite a bit of money to get a good boost in benchmarks; either go the Velociraptor route or RAID (or both if cost is not an option). But that will give you a boost in bechmarks and not that much in real world use. It will speed up your load times but not much else.
The new crop of SSDs are coming in the near future. SSDs usually have stunning seek speeds and good read times. They will also increase competition and drive down the cost of existing drives.
And x-mess sales will be starting up soon.
enaberif September 2, 2008 03:57 AM
Incorrect.
Raptor drives are only going to show very little difference in load times not game play.
Just keep your drives they are plenty fast.
Worry about upgrading cpu, ram, or gpu more than anything else.
yamawho September 2, 2008 05:47 AM
I agree, I had a raid 0 setup for years and load times were the only benefit.
DK2 September 2, 2008 06:24 AM
faster HDD won't gain you much, a little faster initial startup, and loading levels, if any.
After that games really only stream the music, which is nothing for any HDD even a USB one.
Most games give you an option to install anywhere you like if you choose custom install, and 95% of the files get installed there, and a few setup/savegames might go somewhere in the Documants folder.
Hillsdale September 2, 2008 10:42 AM
I think im just going to wait for the x58 to come out with the Nehalm and upgrade to that with ddr3 ram and i might get a new Velociraptor aswell, but that wont be until the Nehalm has its first price drop
enaberif September 2, 2008 12:22 PM
will all be a waste of money and time.
