-   -   Are there any 16G MicroSDHC's? (http://www.hardwarecanucks.com/forum/storage/9639-there-any-16g-microsdhcs.html)
howdid August 26, 2008 01:14 AM
im looking to buy a new cell phone that uses the Micro SD memory sticks
NCIX and most places sell 8G MicroSDHC memory cards for around $35
i was wondering if any of you guys know if there are 16Gb versions of these?
It seems likely since $35 is very cheap to be the best capacity out right now
Dashock August 26, 2008 08:52 AM
havent seen em yet Sandisk brand has the best compatability in cellphone applications i have always used it and never had a problem currently buying an 8gb SDHC micro sd for my MotorolaQ9h but i do not believe the 16gb is out yet i think Sandisk has a 12 out if im not mistaken anyways depending on what phone you have make sure the brand you are getting is compatiable.
howdid August 26, 2008 10:42 AM
im either gonna buy a Nokia N82 or the Samsung i900
i will use them for music and camera etc so i need good memory
