  #21 (permalink)
Old August 10, 2008, 08:24 PM
Level up: 17% Level up: 17% Level up: 17%
Level: 7 - 115 points to level up
Originally Posted by enaberif View Post
Windows Boot Menu is severely limiting.
You'll need a 3rd party boot menu to run multiple OS's
How limiting, in what way? Is there a limited number of operating systems it can handle?
  #22 (permalink)
Old August 11, 2008, 07:10 AM
ipaine's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 9 - 108 points to level up
I'm not sure of the older windows bootloader from XP, but what is included in Vista is not limited in any way that I know of. The thing is to edit the Vista bootloader you need to use "bcdedit.exe" and the command line. Of course if you are not comfortable with that then use something like EasyBCD. Using a bootloader tweaker like that you have a very easy way to get the Vista bootloader to load into pretty much any OS including Mac OS X, Linux, BSD, ReactOS, SkyOS, OS/2, Unix, Dos, legacy versions of Windows, and others.
Here is a great site that has a really good guide for doing such setups and I have personally used it and it has been very benifical.
The definitive dual-booting guide: Linux, Vista and XP step-by-step
I hope some of that helps out.
Antec 900 - Asus P5N-E SLI - Corsair HX620W - Intel Q6600 @2.63GHz - Arctic Cooling Freezer 7 Pro - 4GB (2x2GB) Mushkin HP2-6400 @ 879Mhz 5-4-4-12
eVGA 8800GT w/Akimbo cooler SLI'd @700/1728/1000 -
Samsung SyncMaster 2253BW - Dell 1907FP - Vista/XP dual boot
  #23 (permalink)
Old August 13, 2008, 07:54 PM
Thanks for the link ipaine.
