| If you've got access to a working computer with a burner you can try burning the ISO to MCNLive linux distro MCNLive - Live USB :: News . This is the only live distro I've found that easily allows NTFS drives to be read and burnt to CD for backup purposes. It's been a while since I used it, but you need to use the switch which loads it into memory rather than running straight from the cd. (This allows you to use the cd for burning).
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW DFI P965-S Dark / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
| You could try Spinrite. GRC*|*SpinRite 5.0 to 6.0** I have never used it but the reviews are almost miraculous. (Please post your experience if you try it.) If you can boot from another drive or from a liveCD and mount the partition on your busted drive it is unlikely that copying the data off it will cause more dammage.
__________________ Companion - E8400 - P5K SE - EN8600GT SILENT - 2x1G Ballistix (POS) - WD250 - X241W Server - Q6600 - P5E WS Pro - EAH3450 - 4X2G Redline - WD250 - Pioneer DVD-212 On the shelf - P5N32-E SLI - BFG 8800GTS 640M OC2 - Ballistix 2x1G 8500 4-4-4-12 - X-Fi Fatal1ty - 1xWD 150 Raptor |
| Plugging it in as a secondary drive is a good cheap way to start. wither it works or not depends on what is wrong with the drive.
__________________ - Custom Armor case / Gigabyte X48T / Q9550 3.2GHz / Coolit Elite CPU Cooler / OCZ Platinum 4GB DDR3 EVGA GTX 280 SSC / 2x VelociRaptor HDD RAID0 / 2x HDD 750GB / 2x Samsung DVD Burners Razer AC-1 Sound card / 6600GT video card / ToughPower 850 Watts / 24 & 20 inch Monitors My Pet Monster |
| 1700$ is a totally reasonable quote , just for your knowledge.Professional data recovery is expensive....They rebuild your harddrive in a clean room , substituting the busted parts. Here's what you want to do ; Get a machine thats werking , install R-studio on that rig. Shut that machine off , plug yer drive in, reboot it. Run r-studio.Be patient it takes many hours.You may find it necissary to delete files from previous deletions.(yes it recovers deleted files too).....save the recovered files to new HDD. Good luck.You might get it back , you might not. If you have questions about r-studio , I'll try to help.
__________________ Intel Q9450 /Asus Maximus Formula/Mushkin 6400 /bfg 8800gtx/WD raptors/etc... Last edited by BrainEater : June 23, 2008 at 06:10 PM. |
| i have bought the ZAR recovery program and it has same a few buds data on dying hard drive or corrupted partition,
__________________ DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.8Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Corsair 620W PSU / 2*Seagate 80Gb DFI LP Nf2 Ultra-B / AMD Athlon XP-M 2500+ @ 2.4Ghz/ CENTON DDR400 TCCD / Evga 6800 AGP / FORTRON 450W PSU / 2* Maxtor 80GB ASUS A7N8X / AMD Athlon XP-M 1900+ @ 1800Mhz/ Corsair XMS 2*512 / BBATI 9800pro AGP / FORTRON 450W PSU / Maxtor 80GB + 120GB ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB |
| Depending on the size of drive, $1700 is VERY expensive. If it's under 500GB a single drive non-RAID should be under $1000. There's a few things you want to know before attempting anything: Software isn't foolproof. It MAY bork your drive more than it already is. While a recovery center is more expensive, they're usually guaranteed. Software is NOT. How much is your data worth to you? I used to have a link to a cheap but reliable (about $800 in your case I think) place, but I can't for the life of me find the link. |
| Thread Tools | Search this Thread |
| Display Modes | |
